주요 콘텐츠로 건너뛰기
One Education Infinity:One Battery Replacement
필요한 것
  1. One Education Infinity:One Battery Replacement, Top Case: 1 단계, 이미지 1/3 One Education Infinity:One Battery Replacement, Top Case: 1 단계, 이미지 2/3 One Education Infinity:One Battery Replacement, Top Case: 1 단계, 이미지 3/3
    • Insert a Jimmy or other prying tool into the seam between the screen and back case.
    • Trace around the edges until all clips are released.
    • Lift the back case away from the tablet.
  2. One Education Infinity:One Battery Replacement, Battery: 2 단계, 이미지 1/2 One Education Infinity:One Battery Replacement, Battery: 2 단계, 이미지 2/2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  3. One Education Infinity:One Battery Replacement: 3 단계, 이미지 1/3 One Education Infinity:One Battery Replacement: 3 단계, 이미지 2/3 One Education Infinity:One Battery Replacement: 3 단계, 이미지 3/3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  4. One Education Infinity:One Battery Replacement: 4 단계, 이미지 1/3 One Education Infinity:One Battery Replacement: 4 단계, 이미지 2/3 One Education Infinity:One Battery Replacement: 4 단계, 이미지 3/3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  5. One Education Infinity:One Battery Replacement: 5 단계, 이미지 1/1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Taylor Bratsch
회원 가입일: 09/06/16
5,742 평판
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 983
