주요 콘텐츠로 건너뛰기
One Education Infinity:One Daughterboard Replacement
필요한 것
  1. One Education Infinity:One Daughterboard Replacement, Back Case: 1 단계, 이미지 2개 중 1개 One Education Infinity:One Daughterboard Replacement, Back Case: 1 단계, 이미지 2개 중 2개
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Daughterboard Replacement: 2 단계, 이미지 2개 중 1개 One Education Infinity:One Daughterboard Replacement: 2 단계, 이미지 2개 중 2개
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Daughterboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Daughterboard Replacement: 4 단계, 이미지 2개 중 1개 One Education Infinity:One Daughterboard Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Daughterboard Replacement, Daughterboard: 5 단계, 이미지 2개 중 1개 One Education Infinity:One Daughterboard Replacement, Daughterboard: 5 단계, 이미지 2개 중 2개
    • Flip up the black retaining flap on the ZIF connector holding the large grey ribbon cable in place.
    • Pull the ribbon cable straight out of the ZIF connector.
  6. One Education Infinity:One Daughterboard Replacement: 6 단계, 이미지 2개 중 1개 One Education Infinity:One Daughterboard Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the flat end of a spudger to flip up the black tab on the smaller ZIF connector.
    • Use tweezers to pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Daughterboard Replacement: 7 단계, 이미지 3개 중 1개 One Education Infinity:One Daughterboard Replacement: 7 단계, 이미지 3개 중 2개 One Education Infinity:One Daughterboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to unscrew the three 3.4mm screws.
    • Lift the daughterboard away from the device to remove.
결론
작성자
2다른 기여자 명과 함께
Taylor Bratsch
회원 가입일: 09/06/16
6,083 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 2
전체 시간: 342
