주요 콘텐츠로 건너뛰기
One Education Infinity:One Dock Contact Assembly Replacement
필요한 것
  1. One Education Infinity:One Dock Contact Assembly Replacement, Battery: 1 단계, 이미지 2개 중 1개 One Education Infinity:One Dock Contact Assembly Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Dock Contact Assembly Replacement: 2 단계, 이미지 3개 중 1개 One Education Infinity:One Dock Contact Assembly Replacement: 2 단계, 이미지 3개 중 2개 One Education Infinity:One Dock Contact Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Dock Contact Assembly Replacement: 3 단계, 이미지 3개 중 1개 One Education Infinity:One Dock Contact Assembly Replacement: 3 단계, 이미지 3개 중 2개 One Education Infinity:One Dock Contact Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Dock Contact Assembly Replacement: 4 단계, 이미지 1개 중 1개
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Dock Contact Assembly Replacement, Dock Contact Assembly: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to pull the dock contact display cable away from the connector on the motherboard.
  6. One Education Infinity:One Dock Contact Assembly Replacement: 6 단계, 이미지 1개 중 1개
    • Use a Phillips #000 screwdriver to unscrew the two 4.2mm screws from the circuit board containing the dock contact.
  7. One Education Infinity:One Dock Contact Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • Lift the dock contact assembly away from the device.
결론
작성자
3다른 기여자 명과 함께
Taylor Bratsch
회원 가입일: 09/06/16
6,083 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 237
