주요 콘텐츠로 건너뛰기
One Education Infinity:One Hinge Contact Assembly Replacement
필요한 것
  1. One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: 1 단계, 이미지 1/2 One Education Infinity:One Hinge Contact Assembly Replacement, Back Case: 1 단계, 이미지 2/2
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Hinge Contact Assembly Replacement: 2 단계, 이미지 1/2 One Education Infinity:One Hinge Contact Assembly Replacement: 2 단계, 이미지 2/2
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Hinge Contact Assembly Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Hinge Contact Assembly Replacement: 4 단계, 이미지 1/2 One Education Infinity:One Hinge Contact Assembly Replacement: 4 단계, 이미지 2/2
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: 5 단계, 이미지 1/2 One Education Infinity:One Hinge Contact Assembly Replacement, Hinge Contact Assembly: 5 단계, 이미지 2/2
    • Lift the hinge away from the device.
  6. One Education Infinity:One Hinge Contact Assembly Replacement: 6 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to unscrew the two 6.5mm screws.
  7. One Education Infinity:One Hinge Contact Assembly Replacement: 7 단계, 이미지 1/2 One Education Infinity:One Hinge Contact Assembly Replacement: 7 단계, 이미지 2/2
    • Slide a Jimmy or other prying tool along the seam of the hinge to pry the casing apart.
  8. One Education Infinity:One Hinge Contact Assembly Replacement: 8 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two 4.3mm screws holding the circuit board in place.
  9. One Education Infinity:One Hinge Contact Assembly Replacement: 9 단계, 이미지 1/1
    • Use a spudger to pry the circuit board away from the casing.
    • Always use ESD safe tools when removing delicate components.
결론
Taylor Bratsch
회원 가입일: 09/06/16
5,747 평판
안내서 14개 작성하였습니다
댓글 한 개
Everything is very detailed and shown. Everything is also done in detail on this site ++https://oceanessay.com/buy-thesis-pape... , which helps students learn. There you will find a lot of educational materials.
Nathan Joyce - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 12
전체 시간: 208
