주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
One Education Infinity:One Keyboard Replacement
필요한 것
  1. One Education Infinity:One Keyboard Replacement, Back Case: 1 단계, 이미지 2개 중 1개 One Education Infinity:One Keyboard Replacement, Back Case: 1 단계, 이미지 2개 중 2개
    • Use a spudger to pry the four rubber pads away from the bottom of the case.
    • Use a Phillips #00 screwdriver to unscrew the four 6.4 mm screws.
  2. One Education Infinity:One Keyboard Replacement: 2 단계, 이미지 2개 중 1개 One Education Infinity:One Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Insert a Jimmy or other prying tool into the seam on the edge of the casing.
    • Trace along the edges of the device until all clips are released.
    • Lift the back case away from the device.
  3. One Education Infinity:One Keyboard Replacement: 3 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws on the hinge mounts.
  4. One Education Infinity:One Keyboard Replacement: 4 단계, 이미지 2개 중 1개 One Education Infinity:One Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to lift the fabric cover and hinge connector away from the daughterboard.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Keyboard Replacement, Daughterboard: 5 단계, 이미지 2개 중 1개 One Education Infinity:One Keyboard Replacement, Daughterboard: 5 단계, 이미지 2개 중 2개
    • Flip up the black retaining flap on the ZIF connector holding the large grey ribbon cable in place.
    • Pull the ribbon cable straight out of the ZIF connector.
  6. One Education Infinity:One Keyboard Replacement: 6 단계, 이미지 2개 중 1개 One Education Infinity:One Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the flat end of a spudger to flip up the black tab on the smaller ZIF connector.
    • Use tweezers to pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Keyboard Replacement: 7 단계, 이미지 3개 중 1개 One Education Infinity:One Keyboard Replacement: 7 단계, 이미지 3개 중 2개 One Education Infinity:One Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Use a Phillips #000 screwdriver to unscrew the three 3.4mm screws.
    • Lift the daughterboard away from the device to remove.
  8. One Education Infinity:One Keyboard Replacement, Keyboard Frame Prerequisite: 8 단계, 이미지 2개 중 1개 One Education Infinity:One Keyboard Replacement, Keyboard Frame Prerequisite: 8 단계, 이미지 2개 중 2개
    • Use a spudger to lift up the black retaining flap on the touchpad's ZIF connector.
    • Pull the ribbon cable straight back to remove.
  9. One Education Infinity:One Keyboard Replacement: 9 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to unscrew the four 6.4mm screws holding the touchpad in place.
  10. One Education Infinity:One Keyboard Replacement: 10 단계, 이미지 2개 중 1개 One Education Infinity:One Keyboard Replacement: 10 단계, 이미지 2개 중 2개
    • Feed the ribbon cable through the hole in the metal frame.
    • Left the metal frame away from the device.
  11. One Education Infinity:One Keyboard Replacement, Keyboard: 11 단계, 이미지 1개 중 1개
    • Lift one end of the keyboard up to peel it away from the case.
    • Don't be alarmed if you hear cracking sounds as you pry the keyboard away from the frame. There are dozens of plastic rivets holding the keyboard to the plastic frame.
결론
작성자
1다른 기여자 명과 함께
Taylor Bratsch
회원 가입일: 09/06/16
6,150 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 34
전체 시간: 418
