주요 콘텐츠로 건너뛰기
One Education Infinity:One Motherboard Replacement
필요한 것
  1. One Education Infinity:One Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 One Education Infinity:One Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Motherboard Replacement: 2 단계, 이미지 3개 중 1개 One Education Infinity:One Motherboard Replacement: 2 단계, 이미지 3개 중 2개 One Education Infinity:One Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Motherboard Replacement: 3 단계, 이미지 3개 중 1개 One Education Infinity:One Motherboard Replacement: 3 단계, 이미지 3개 중 2개 One Education Infinity:One Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Motherboard Replacement, Antenna: 5 단계, 이미지 2개 중 1개 One Education Infinity:One Motherboard Replacement, Antenna: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use ESD safe tweezers to disconnect the antenna from the motherboard.
  6. One Education Infinity:One Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 One Education Infinity:One Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 One Education Infinity:One Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  7. One Education Infinity:One Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to pull the dock connection cable away from the motherboard.
  8. One Education Infinity:One Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to unscrew the two 3.4 mm screws.
    • Use a Phillips #000 screwdriver to unscrew the one 4.2mm screw.
  9. One Education Infinity:One Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Lift the protective shield away from the motherboard.
  10. One Education Infinity:One Motherboard Replacement: 10 단계, 이미지 3개 중 1개 One Education Infinity:One Motherboard Replacement: 10 단계, 이미지 3개 중 2개 One Education Infinity:One Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • With the flat end of a spudger, flip up the black flap on the display's ZIF connector.
    • Insert the pointed end of the spudger between the cable and the motherboard and gently pull the cable straight out of the connector.
    • During reassembly, be sure to insert the cable into the connector up to the white line on the cable and then close the retaining flap.
  11. One Education Infinity:One Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    • Gently lift the motherboard away from the display assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Taylor Bratsch
회원 가입일: 09/06/16
6,083 평판
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 623
