소개
If your OneLink Safe and Sound device is in need of replacement, follow this step-by-step speaker replacement guide.
Please follow all steps to successfully disassemble the speakers for a seamless replacement.
필요한 것
Run the metal spudger under the plastic rim and around the perimeter, on the top of the device to loosen the adhesive.
Remove plastic rim.
Use the opening tool to disconnect the Wi-Fi cable from the Bluetooth module.
Use the opening tool to disconnect the speaker cables from the daughterboard.
Use the opening to lift the daughterboard off of the motherboard.
Remove the speaker cables from the channels along the edge of the speaker cover.
Use an opening tool or your fingers to lift the speaker cover off of the back cover which houses the speakers.
