소개
If you have have noticed your phone charge dying rapidly or inconsistently, perhaps it's time to replace your battery. This guide will show you how to do that.
필요한 것
Make sure that your phone is turned off before proceeding
Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
Find and carefully remove all 6 rubber screw covers with the tweezers.
Unscrew all 18 screws from the mid frame.
Using the spudger tool, pry the battery up from the adhesive.
Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
The battery connection was under a black tape in my phone. Remove the tape strip first.
Removing the battery was really difficult. I had to apply a lot of force. You think something is going to break, but it eventually comes loose.
Followed the procedure and all worked as expected. Thanks for this tutorial.
다른 98명이 해당 안내서를 완성하였습니다.
댓글 21개
Nice to see that, thanx !
But do you know where it's possible to buy a new battery ?
I see "designed by oneplus" on it and I'm not sure it would be easy to find one on internet usual stores.
Fred Hamel - 답글
You can look up a oneplus service center in your country/locality by going to your country's version of the oneplus site. There in the support -->Contact Us, you will find a list of places(service centers) you can go for repairs and a price list of all the parts and the service to replace them. Not sure if this works for every country, worked for me.
this is not a full help.. how do we suppose to buy official battery for onelus2?
and this method would be great if you upload a video in full detail without missing any point.
so, please do that. Thanks in advance!
Use google.com and search for BLP597 that's the itemnumber of the battery in question. There are plenty of sellers available.
any good battery for oneplus 2? i wanna buy a new battery for oneplus 2 can you please suggest me good battery for it? please tell me i really need it asap.
Thank you!!
Am baterie nouă, vrei?
Thanks for your help, I bought my battery from ebay.com and it works fine and easy to replace. But I bought first battery when i received it i found it not looking new so I returned it then buy new one look new and working good.
big thanks :)
Hey, could anyone please send me a link to where you bought the battery from.?
I’ve recently bought one on Ebay.de and it did not fit. Took for ages to deliver to Poland and then I had to pay for the return cost.
Hi.
You can get a replacement battery from “ www dot witrigs dot com/accessories-for-oneplus-two”. Can’t put the link in as the automated spam system blocks it. You can also find it on ebay if you’ll search for “Replace for OnePlus Two 2 A002 Blp597 3300mah Internal Battery”
Hope it helps
Hi, after a couple of years my oneplus 2 started to had a really bad battery life so I ordered an original battery and replaced it with your manual. Thanks at first place for this detailed instructions. Sadly it starts to boot up and then immediately turns off. Then it restarts and there is the message shown that the device temperature is to high. Does anyone of you has an idea what this could cause? I was very careful while changing the battery. Thanks in advance
My replacement battery was via Amazon but there are plenty on ebay too. Two commentd - the third “screw cover” red circle from the top is in the wrong place, it should be lower and left of the camera. Slightly more scarily, the battery connector is in the wrong place by a millimter or two, it was the same on the original battery - you need to gently peel the red covering from over the cable to the connector to give it a little extra flexibility.
Sean Kelly - 답글
Thanks for the tip about the screw cover markings; I went ahead and adjusted them so they should be correct now. Looks like someone was in a bit of a hurry when they placed those :p
How hard do you have to pry to free the battery?
I pried hard and the battery bent slightly but seemed to be almost integrated with the frame?
Hi, i’am trying to find where to buy an original battery from france. Actually i ve bought the batery from Alliexpress, and in despite, the batery was described as original, the life cycle was too short. I’ ve tried to call the Technical service, and they can’t sell battery.
So anybody have an idea for me?
Best regard,
see on bol.com
https://www.oneplus.in/experience-servic...
Choose appropriate service center and get it replaced for 1402/- INR. Safe and secure.
This is for INDIA.
For customers in India -
My One Plus 2 just turned 3 years. I went looking for a genuine battery and One Plus customer care wrote back saying that they’ve stopped the supply of parts for the One Plus 2. What an irresponsible company to stop selling batteries for a phone that they released in 2015. Don’t the morons realize that its only after 2-3 years that one needs a new battery?
I am not a guy who would buy a new phone just for the sake of buying one. Besides, its bad for the environment when you throw away a device that has more life in it. So, I keep looking harder and I got lucky when I tried an authorized service center in a smaller town. The proprietor was a gem of a man and he shipped me a new battery in one day! I paid Rs.1402, taxes included.
For friends in India looking to order a genuine One Plus 2 battery, visit the One Plus India service web pagee and search for the service center in “Vijayawada, Andhra Pradesh”.
https://www.oneplus.in/support/service-c...
Cheers!
Suresh R
Helped me, Thank you very much! :-)
On aliexpress are battery with larger capacity
€ 14,85 32%OFF | WISECOCO 4700mAh BLP597 Batterij Voor Oneplus 2 Een Plus 2 Twee A2001 Telefoon Nieuwste Productie Hoge Kwaliteit Batterij + tracking Code
https://s.click.aliexpress.com/e/mlQnd3q...
4700 mAh
Will this battery work in the oneplus 2?
