소개
If you are experiencing trouble chairing or plugging in your phone, there may be something wrong with the charging port. This guide will show you have to remove and replace your charging port.
필요한 것
Make sure that your phone is turned off before proceeding
Use an opening pick, your thumbnail, or a spudger to gently pry off the external casing
Find and carefully remove all 6 rubber screw covers with the tweezers.
Unscrew all 18 screws from the mid frame.
Using the spudger tool, pry the battery up from the adhesive.
Once the battery is loose from the adhesive holding it down, use the spudger tool to pry up the connection from the battery to the phone on the top right hand side.
The battery connection was under a black tape in my phone. Remove the tape strip first.
Removing the battery was really difficult. I had to apply a lot of force. You think something is going to break, but it eventually comes loose.
Followed the procedure and all worked as expected. Thanks for this tutorial.
Use the spudger tool to pry up the top connection of the charging port.
Follow the cable with the spudger and slowly pry it up from the adhesive holding it down.
Stop at the next connection.
다른 21명이 해당 안내서를 완성하였습니다.
댓글 9개
I need that part please. I need to buy it my phone stoped charging and need charging port with it's falt cable.. Please help me
My email is :mamdouh1978@gmail.com
I need this part also. You can help me, please?
can you tell me why 2 pins on Charigng Port Flex ?? can I add wireless charger from it? please reply at atulmits@gmail.com
I am looking forward to buy this tool, may I know when will it be available?
helped me, thank you! :-)
