주요 콘텐츠로 건너뛰기
OnePlus 6 Speaker Replacement
필요한 것
  1. OnePlus 6 Speaker Replacement, Back Panel: 1 단계, 이미지 1/1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Speaker Replacement: 2 단계, 이미지 1/2 OnePlus 6 Speaker Replacement: 2 단계, 이미지 2/2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Speaker Replacement: 3 단계, 이미지 1/2 OnePlus 6 Speaker Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Speaker Replacement, Battery: 4 단계, 이미지 1/2 OnePlus 6 Speaker Replacement, Battery: 4 단계, 이미지 2/2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
  5. OnePlus 6 Speaker Replacement, Speaker: 5 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the eight screws.
    • Carefully lift the speaker up and out of the chassis.
    • If you're completing a screen replacement, skip to Step 9.
  6. OnePlus 6 Speaker Replacement: 6 단계, 이미지 1/1
    • Properly orient the new speaker unit and use a Phillips #000 screwdriver to replace the eight screws removed from the previous step.
  7. OnePlus 6 Speaker Replacement: 7 단계, 이미지 1/1
    • Place the battery back into the phone and connect it to the same port, making sure to firmly press the connection down into place.
    • Place the red cover back over the top of the port.
  8. OnePlus 6 Speaker Replacement: 8 단계, 이미지 1/1
    • Strip the existing adhesive, and place new adhesive around the entire perimeter of the back cover.
    • Replace the back cover and hold it down for about a minute to to let the adhesive set.
결론
Enjoy your new speaker!
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 29
전체 시간: 639
