주요 콘텐츠로 건너뛰기
OnePlus 7 Pro Battery Cover Replacement
필요한 것
동영상 개요
  1. OnePlus 7 Pro Battery Cover Replacement, OnePlus 7 Pro Battery Cover  Replacement: 1 단계, 이미지 1/3 OnePlus 7 Pro Battery Cover Replacement, OnePlus 7 Pro Battery Cover  Replacement: 1 단계, 이미지 2/3 OnePlus 7 Pro Battery Cover Replacement, OnePlus 7 Pro Battery Cover  Replacement: 1 단계, 이미지 3/3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. OnePlus 7 Pro Battery Cover Replacement: 2 단계, 이미지 1/2 OnePlus 7 Pro Battery Cover Replacement: 2 단계, 이미지 2/2
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
  3. OnePlus 7 Pro Battery Cover Replacement: 3 단계, 이미지 1/3 OnePlus 7 Pro Battery Cover Replacement: 3 단계, 이미지 2/3 OnePlus 7 Pro Battery Cover Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  4. OnePlus 7 Pro Battery Cover Replacement: 4 단계, 이미지 1/3 OnePlus 7 Pro Battery Cover Replacement: 4 단계, 이미지 2/3 OnePlus 7 Pro Battery Cover Replacement: 4 단계, 이미지 3/3
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  5. OnePlus 7 Pro Battery Cover Replacement: 5 단계, 이미지 1/2 OnePlus 7 Pro Battery Cover Replacement: 5 단계, 이미지 2/2
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  6. OnePlus 7 Pro Battery Cover Replacement: 6 단계, 이미지 1/3 OnePlus 7 Pro Battery Cover Replacement: 6 단계, 이미지 2/3 OnePlus 7 Pro Battery Cover Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to lift up the piece of black tape covering the laser autofocus and flash flex cable.
    • Use a pair of tweezers to lift and remove the covering on the laser autofocus and flash flex cable.
  7. OnePlus 7 Pro Battery Cover Replacement: 7 단계, 이미지 1/1
    • Use the flat end of a spudger to disconnect the laser autofocus and flash flex cable.
  8. OnePlus 7 Pro Battery Cover Replacement: 8 단계, 이미지 1/2 OnePlus 7 Pro Battery Cover Replacement: 8 단계, 이미지 2/2
    • Peel off the adhesive cover for the new battery cover.
결론
To reassemble your device, replace the battery cover and follow these instructions in reverse order.
다른 9명이 해당 안내서를 완성하였습니다.
Selena
회원 가입일: 12/15/19
2,686 평판
안내서 14개 작성하였습니다
댓글 한 개
Could this be used and adapted to replace the charging port?
S. S. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 28
30일 전: 63
전체 시간: 9,311
