주요 콘텐츠로 건너뛰기
OnePlus 8T Rear Glass Replacement
필요한 것
  1. OnePlus 8T Rear Glass Replacement, Heat the rear glass: 1 단계, 이미지 1개 중 1개
    • Switch off your phone.
    • Heat an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the rear glass removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. OnePlus 8T Rear Glass Replacement, Create a gap: 2 단계, 이미지 3개 중 1개 OnePlus 8T Rear Glass Replacement, Create a gap: 2 단계, 이미지 3개 중 2개 OnePlus 8T Rear Glass Replacement, Create a gap: 2 단계, 이미지 3개 중 3개
    • Apply a suction cup to the back of the phone, as close as possible to the center of the bottom edge.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull on the suction cup to create a gap between the rear glass and the frame.
    • Insert the tip of an opening pick into the gap and slide it to the bottom left corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  3. OnePlus 8T Rear Glass Replacement, Slice the adhesive: 3 단계, 이미지 2개 중 1개 OnePlus 8T Rear Glass Replacement, Slice the adhesive: 3 단계, 이미지 2개 중 2개
    • Insert a second opening under the bottom left corner.
    • Slide the opening pick along the bottom edge to the bottom right corner.
    • Leave the pick in its place to prevent the adhesive from resealing.
  4. OnePlus 8T Rear Glass Replacement, Slice the adhesive: 4 단계, 이미지 3개 중 1개 OnePlus 8T Rear Glass Replacement, Slice the adhesive: 4 단계, 이미지 3개 중 2개 OnePlus 8T Rear Glass Replacement, Slice the adhesive: 4 단계, 이미지 3개 중 3개
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener to reheat it.
    • Insert a third opening pick under the bottom right corner.
    • Slide the opening pick along the right edge to the top right corner.
    • Leave the opening picks in their place to prevent the adhesive from resealing.
  5. OnePlus 8T Rear Glass Replacement, Slice the adhesive: 5 단계, 이미지 2개 중 1개 OnePlus 8T Rear Glass Replacement, Slice the adhesive: 5 단계, 이미지 2개 중 2개
    • Insert a fourth opening pick under the top right corner.
    • Slide it along the top edge to the top left corner to cut the adhesive.
  6. OnePlus 8T Rear Glass Replacement, Slice the remaining adhesive: 6 단계, 이미지 3개 중 1개 OnePlus 8T Rear Glass Replacement, Slice the remaining adhesive: 6 단계, 이미지 3개 중 2개 OnePlus 8T Rear Glass Replacement, Slice the remaining adhesive: 6 단계, 이미지 3개 중 3개
    • Insert a fifth opening pick under the top left corner.
    • Slide the opening pick along the left edge to the bottom left corner to cut the remaining adhesive.
  7. OnePlus 8T Rear Glass Replacement, Remove the rear glass: 7 단계, 이미지 1개 중 1개
    • Remove the rear glass.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
결론
Secure the new rear glass cover with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
다른 9명이 해당 안내서를 완성하였습니다.
Adriana Zwink
회원 가입일: 12/18/19
62,043 평판
안내서 167개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,638개를 작성함
3가이드 댓글
Hi, is possible to remove the protection Lens ?
G4seb - 답글
Deze handleiding stopt bij het verwijderen van de oude achterkant, het plaatsen van de nieuwe wordt hier niet behandeld.
Hoe lijm je de nieuwe achterkant weer vast? Moet je daarvoor speciale lijm gebruiken of wordt dit bij de nieuwe achterkant geleverd?
Moet je dit ook weer verwarmen of is het voldoende om druk te geven met een paar boeken?
JohanS - 답글
Der Kleber wird in der Regel mit der neuen Rückseite mitgeliefert. Dieser muss nicht erhitzt werden, um zu kleben. Nach dem Austausch des Rückglases, kann die Beschwerung durch ein paar schwere Bücher helfen, die Rückseite gut und fest anzukleben.
Moritz S -
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 35
지난 30일: 209
전체 시간: 17,873
