주요 콘텐츠로 건너뛰기
OnePlus Nord N200 Back Cover Replacement
필요한 것
  1. OnePlus Nord N200 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/3 OnePlus Nord N200 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/3 OnePlus Nord N200 Back Cover Replacement, Back Cover: 1 단계, 이미지 3/3
    • Due to its surface, the suction tool won't hold onto the phone's rear glass. A thin slicing tool is required.
    • Insert the Jimmy into the seam between the rear glass and the midframe at the bottom edge of the phone to create a gap.
    • This may require some force.
    • Leave the Jimmy in place for a few seconds to prevent the adhesive from resealing.
  2. OnePlus Nord N200 Back Cover Replacement: 2 단계, 이미지 1/3 OnePlus Nord N200 Back Cover Replacement: 2 단계, 이미지 2/3 OnePlus Nord N200 Back Cover Replacement: 2 단계, 이미지 3/3
    • Insert an iFixit opening pick into the gap you created with the Jimmy.
    • Slide the Jimmy around the phone to slice the adhesive.
    • Insert a second iFixit opening pick at the spot you have sliced open to keep it open.
  3. OnePlus Nord N200 Back Cover Replacement: 3 단계, 이미지 1/3 OnePlus Nord N200 Back Cover Replacement: 3 단계, 이미지 2/3 OnePlus Nord N200 Back Cover Replacement: 3 단계, 이미지 3/3
    • Slide the iFixit opening pick along the top edge to slice the adhesive.
    • Start prying the back plate off the phone.
  4. OnePlus Nord N200 Back Cover Replacement: 4 단계, 이미지 1/3 OnePlus Nord N200 Back Cover Replacement: 4 단계, 이미지 2/3 OnePlus Nord N200 Back Cover Replacement: 4 단계, 이미지 3/3
    • Remove the back cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Fabrise Niyonkuru
회원 가입일: 03/18/24
1,069 평판
안내서 9개 작성하였습니다
UMass Dartmouth, Team 1-1, Konn Spring 2024 UMass Dartmouth, Team 1-1, Konn Spring 2024 회원
UMASSD-KONN-S24S1G1
4 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 24
전체 시간: 66
