주요 콘텐츠로 건너뛰기
OnePlus One Motherboard Replacement
필요한 것
  1. OnePlus One Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 OnePlus One Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 OnePlus One Motherboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the SIM tray.
    • Using a plastic opening tool, carefully separate the back panel from the main body assembly of the phone. Be extra careful around the SIM slot or other weak areas.
    • You may encounter some resistance due to hidden locking clips around the inside edge of the phone. Not to worry; just move in one consistent direction around the phone as opposed to jumping from spot to spot!
    • Top to bottom, left to right, clockwise or counter clockwise, once we make it about half way around the device, the panel is easily removable by hand.
    • It is of utmost importance that you do not attempt to free the battery from the device at this point without proceeding to the following step! This is an integrated battery that can easily be damaged or destroyed if the proper steps are are not taken.
  2. OnePlus One Motherboard Replacement: 2 단계, 이미지 3개 중 1개 OnePlus One Motherboard Replacement: 2 단계, 이미지 3개 중 2개 OnePlus One Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a pair of tweezers, remove the plastic plugs.
    • Once the hidden screws are revealed, use a PH #00 screwdriver to remove the three 3.175mm screws.
    • Use the PH #00 screwdriver to remove the remaining six 3.175 screws.
  3. OnePlus One Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, gently pry up the black plastic cover and remove it from the device.
  4. OnePlus One Motherboard Replacement: 4 단계, 이미지 3개 중 1개 OnePlus One Motherboard Replacement: 4 단계, 이미지 3개 중 2개 OnePlus One Motherboard Replacement: 4 단계, 이미지 3개 중 3개
    • After we have removed the motherboard cover, we notice that the battery is intact and has a black ribbon attached to it, which is mounted on the logic board.
    • Using the spudger, carefully begin to lift the the battery up from the side opposite the ribbon. Be aware that there is high-grade adhesive holding the battery in its bay, so proceed with caution.
    • This battery is not encased in a hard shell so it is soft and malleable. Caution must be taken during removal so as not to cause permanent damage.
  5. OnePlus One Motherboard Replacement: 5 단계, 이미지 3개 중 1개 OnePlus One Motherboard Replacement: 5 단계, 이미지 3개 중 2개 OnePlus One Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Once the battery has been freed, we use the ever handy black spudger to pry up and free the battery ribbon from its dock.
    • You can disconnect the battery before freeing it to make removal easier.
  6. OnePlus One Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 1개 OnePlus One Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 2개 OnePlus One Motherboard Replacement, Motherboard: 6 단계, 이미지 3개 중 3개
    • Using a black spudger, disconnect all connectors by lifting up gently.
  7. OnePlus One Motherboard Replacement: 7 단계, 이미지 2개 중 1개 OnePlus One Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using a pair of tweezers, gently lift the front facing camera out of the device.
  8. OnePlus One Motherboard Replacement: 8 단계, 이미지 3개 중 1개 OnePlus One Motherboard Replacement: 8 단계, 이미지 3개 중 2개 OnePlus One Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Gently lift the top side of the motherboard and disconnect the antenna to free it from the device.
    • The volume and power buttons are soldered onto the motherboard and must be removed with it. To make the process easier, gently pry the buttons out before removing the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Justin Ogihara
회원 가입일: 09/18/17
30,324 평판
안내서 52개를 작성함
2가이드 댓글
Your post is very meticulous and impressive for me, I hope to get more good posts. powerline io
bearpu1994 - 답글
I do have an extra metal sheet on top of the motherboard covering the chipsets like a heatsink. How did you remove that?
András Jacsó - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 69
전체 시간: 4,534
