주요 콘텐츠로 건너뛰기
Onkyo TX-800 Button Pins Repair
필요한 것
  1. Onkyo TX-800 Button Pins Repair, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 1/3 Onkyo TX-800 Button Pins Repair, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 2/3 Onkyo TX-800 Button Pins Repair, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 3/3
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Onkyo TX-800 Button Pins Repair: 2 단계, 이미지 1/2 Onkyo TX-800 Button Pins Repair: 2 단계, 이미지 2/2
    • Remove the top screw on the back panel.
  3. Onkyo TX-800 Button Pins Repair: 3 단계, 이미지 1/2 Onkyo TX-800 Button Pins Repair: 3 단계, 이미지 2/2
    • Slide off the case to expose the internal components of the receiver.
  4. Onkyo TX-800 Button Pins Repair, Face plate: 4 단계, 이미지 1/3 Onkyo TX-800 Button Pins Repair, Face plate: 4 단계, 이미지 2/3 Onkyo TX-800 Button Pins Repair, Face plate: 4 단계, 이미지 3/3
    • Unscrew the three screws on top of the face plate.
  5. Onkyo TX-800 Button Pins Repair: 5 단계, 이미지 1/2 Onkyo TX-800 Button Pins Repair: 5 단계, 이미지 2/2
    • Unscrew the one screw on the bottom of the front panel.
  6. Onkyo TX-800 Button Pins Repair: 6 단계, 이미지 1/3 Onkyo TX-800 Button Pins Repair: 6 단계, 이미지 2/3 Onkyo TX-800 Button Pins Repair: 6 단계, 이미지 3/3
    • Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
  7. Onkyo TX-800 Button Pins Repair, Logic board: 7 단계, 이미지 1/3 Onkyo TX-800 Button Pins Repair, Logic board: 7 단계, 이미지 2/3 Onkyo TX-800 Button Pins Repair, Logic board: 7 단계, 이미지 3/3
    • On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
  8. Onkyo TX-800 Button Pins Repair: 8 단계, 이미지 1/2 Onkyo TX-800 Button Pins Repair: 8 단계, 이미지 2/2
    • You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up.
  9. Onkyo TX-800 Button Pins Repair, Onkyo TX-800 Button Pins Repair: 9 단계, 이미지 1/2 Onkyo TX-800 Button Pins Repair, Onkyo TX-800 Button Pins Repair: 9 단계, 이미지 2/2
    • You will see that each button on the face plate has a button pin that presses the corresponding button on the logic board. Visually check if any of these pins are bent or broken.
  10. Onkyo TX-800 Button Pins Repair: 10 단계, 이미지 1/1
    • If any of the pins are bent use your pliers to bend the pins back into shape.
    • Take caution that too much force can break the button pins.
결론
Ryan
회원 가입일: 04/13/10
108 평판
안내서 3개 작성하였습니다
Cal Poly, Team 27-92, Amido Spring 2010 Cal Poly, Team 27-92, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G92
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 5,162
