이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
Simultaneously push down on the head of the snap on each end of the device with your thumbs and push to seperate the face plate. This may take some force.
On the inside middle of the face plate you will see two screws in the logic board. Unscrew these two screws.
You will see the same snaps along the top of the logic board. Press the heads of the snaps down and pull the logic board out and up.
You will see that each button on the face plate has a button pin that presses the corresponding button on the logic board. Visually check if any of these pins are bent or broken.
If any of the pins are bent use your pliers to bend the pins back into shape.
