주요 콘텐츠로 건너뛰기
Onkyo TX-800 Power fuse Replacement
필요한 것
  1. Onkyo TX-800 Power fuse Replacement, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 1/3 Onkyo TX-800 Power fuse Replacement, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 2/3 Onkyo TX-800 Power fuse Replacement, Disassembling Onkyo TX-800 Top case: 1 단계, 이미지 3/3
    • Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
  2. Onkyo TX-800 Power fuse Replacement: 2 단계, 이미지 1/2 Onkyo TX-800 Power fuse Replacement: 2 단계, 이미지 2/2
    • Remove the top screw on the back panel.
  3. Onkyo TX-800 Power fuse Replacement: 3 단계, 이미지 1/2 Onkyo TX-800 Power fuse Replacement: 3 단계, 이미지 2/2
    • Slide off the case to expose the internal components of the receiver.
  4. Onkyo TX-800 Power fuse Replacement, Power fuse: 4 단계, 이미지 1/2 Onkyo TX-800 Power fuse Replacement, Power fuse: 4 단계, 이미지 2/2
    • Locate the fuse.
  5. Onkyo TX-800 Power fuse Replacement: 5 단계, 이미지 1/2 Onkyo TX-800 Power fuse Replacement: 5 단계, 이미지 2/2
    • Gently wedge a small screwdriver in between one side of the fuse and the contact.
    • Remove the fuse with your thumb and forefinger.
  6. Onkyo TX-800 Power fuse Replacement: 6 단계, 이미지 1/1
    • Examine the fuse. If the wire within it is broken, you will need to replace it with a new 125 Volt, 4 Amp fuse.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Michael Lady
회원 가입일: 04/09/10
271 평판
안내서 2개 작성하였습니다
Cal Poly, Team 27-92, Amido Spring 2010 Cal Poly, Team 27-92, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G92
4 회원들
안내서 7개 작성하였습니다
댓글 2개
Thanks for clear instructions!
Andy Dersch - 답글
Thank you!
There are no Onkyo repair centers to go to.
obobooks - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 30
30일 전: 104
전체 시간: 18,622
