주요 콘텐츠로 건너뛰기
OontZ Angle 3 Motherboard Replacement
필요한 것
  1. OontZ Angle 3 Motherboard Replacement, Back Case: 1 단계, 이미지 1/3 OontZ Angle 3 Motherboard Replacement, Back Case: 1 단계, 이미지 2/3 OontZ Angle 3 Motherboard Replacement, Back Case: 1 단계, 이미지 3/3
    • Make sure that the OontZ Angle 3 is powered off before starting the disassembly.
    • Use the plastic opening tool to remove the rubber caps from each end of the speaker.
  2. OontZ Angle 3 Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove four (4) 11.7 mm Phillips #0 screws from each side at the bottom of the speaker.
  3. OontZ Angle 3 Motherboard Replacement: 3 단계, 이미지 1/2 OontZ Angle 3 Motherboard Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool on one of the corners to separate the bottom piece from the speaker, and then remove the piece.
  4. OontZ Angle 3 Motherboard Replacement, Motherboard: 4 단계, 이미지 1/3 OontZ Angle 3 Motherboard Replacement, Motherboard: 4 단계, 이미지 2/3 OontZ Angle 3 Motherboard Replacement, Motherboard: 4 단계, 이미지 3/3
    • Locate the soldering connections for the battery on the motherboard and the wires for the speakers.
    • Use the soldering iron to disconnect the battery wires from the motherboard.
    • Use the soldering iron to disconnect the speaker wires from the motherboard.
    • When reconnecting the battery and speakers to the new motherboard, be careful to make the connections to the correct nodes as well as establish a complete connection, as the speakers could break with an incorrect connection and the battery risks overheating or erupting in flames if corrected incorrectly or poorly.
  5. OontZ Angle 3 Motherboard Replacement: 5 단계, 이미지 1/3 OontZ Angle 3 Motherboard Replacement: 5 단계, 이미지 2/3 OontZ Angle 3 Motherboard Replacement: 5 단계, 이미지 3/3
    • Remove the three (3) 3.6mm screws using a Phillips #0 screwdriver.
    • Use the plastic opening tool about midway down one side of the motherboard to pry it out of the casing.
    • Remove the faulty motherboard.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Mason Hollander
회원 가입일: 01/20/16
1,375 평판
안내서 4개 작성하였습니다
USF Tampa, Team 15-6, Remmell Spring 2016 USF Tampa, Team 15-6, Remmell Spring 2016 회원
USFT-REMMELL-S16S15G6
4 회원들
안내서 4개 작성하였습니다
댓글 15개
where do i buy mother board of oontz angle 3?
Jomar Agcaoili - 답글
how much does a new motherboard cost??
Linda Coppola - 답글
Can you post where to get a new MB?
Brian Dickert - 답글
It does require a part...the new motherboard!
Brian Dickert - 답글
I'm having a hard time tracking down motherboards too. But the guide is still helpful if someone wants to harvest a motherboard out of another broken Oontz and use it in their own. If anyone else finds a source for the motherboard, feel free to edit the guide and include a link to it in the details section. Maybe if we all work together we can find a source.
Kelsea Weber - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 13
30일 전: 50
전체 시간: 12,142
