이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Insert the ignition key in the driver's door lock.
Turn the key clockwise to unlock.
Hold the key in this position for 5 seconds.
Press the door unlock button on the remote transmitter.
Press and hold the door unlock button on the remote transmitter a second time.
All the windows roll down simultaneously. Releasing the button stops the windows where they are.
To close all the windows at once, insert the ignition key in the driver's door lock.
Turn the key counterclockwise once to lock the vehicle.
Release the key to the neutral position.
Turn and hold the key counterclockwise again.
The windows begin closing in 5 seconds.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 4개
hi this use to work on my vectra
but not on my sv6 any ideas
This guide is meant for the Honda CL9, sold as the Euro/JDM Accord or US Acura TSX. Your experience will undoubtedly differ with other makes and models. Consult your owners manual or local dealer.
This was very helpful. But I have a 2006 XLE Limited Toyota and it does not work. Any ideas as to why?
Different model car? Check hour car’s manual, or your Toyota dealer. ;)
