이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
The first step is to open the hatch for the batteries. to do this, on the right side there is a door that you push down on and it opens.
Now remove the two s screws highlighted in red.
Now at the bottom of the device there is a screw circled in red that is hidden under a warranty sticker (in blue).
On the top side there is a screw (circled) that is under a little black dot. Peel that dot off with a knife or pointed spudger.
On the right side (battery door hatch side), there is another screw under a black dot.
Now carefully using a spudger or case opening tool, carefully rise the front bezel from the back casing by working around the device.
