소개
Follow this guide to open an iPhone 6s and access internal components for repair or replacement.
필요한 것
Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, on either side of the Lightning connector.
이 단계에 사용된 도구:Anti-Clamp$24.95
If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
다른 8명이 해당 안내서를 완성하였습니다.
