주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Opening the Grinder
필요한 것
  1. Opening the  Grinder, opening procedure: 1 단계, 이미지 1개 중 1개
    • Unplug your coffee maker!
    • Remove the water container, the brew group and the drip tray with pomace container.
    • Using a spoon, remove as much of the coffee beans as possible from the coffee bean container.
    • Depending on the model, additional sensors with cables may be installed on the top and side panels. You have to remove these before you can completely remove the housing parts.
    댓글 쓰기
  2. Opening the  Grinder: 2 단계, 이미지 1개 중 1개
    • Remove the two Torx T10 screws on the top.
    댓글 쓰기
  3. Opening the  Grinder: 3 단계, 이미지 2개 중 1개 Opening the  Grinder: 3 단계, 이미지 2개 중 2개
    • Remove seven T10 Torx screws on the back.
    • The two screws at the bottom of the front can remain.
    댓글 쓰기
  4. Opening the  Grinder: 4 단계, 이미지 2개 중 1개 Opening the  Grinder: 4 단계, 이미지 2개 중 2개
    • Press with a flat-head screwdriver into the openings on the side with the water tank. This releases the latches on the top.
    • Press the flat-head screwdriver into the opening on the side with the brew group. This will release the last notch on the top.
    • Lift the top off.
    • On some models, a cable leads to the sensor on the powder tray. Unplug the connector on this cable first.
    댓글 쓰기
  5. Opening the  Grinder: 5 단계, 이미지 2개 중 1개 Opening the  Grinder: 5 단계, 이미지 2개 중 2개
    • Slide the side section of the brewing unit about 2 cm to the rear. This sometimes gets stuck and may require some force to remove.
    • Remove the two tabs from the power switch.
    • Take off the side panel with the brew group.
    댓글 쓰기
  6. Opening the  Grinder: 6 단계, 이미지 1개 중 1개
    • Do the same with the panel on the other side.
    • To remove the water tank hose simply pull it of the pump.
    • Remove the side panel.
    댓글 쓰기
  7. Opening the  Grinder, Opening the  Grinder: 7 단계, 이미지 2개 중 1개 Opening the  Grinder, Opening the  Grinder: 7 단계, 이미지 2개 중 2개
    • The grinder is situated on the top right rearside of the device. The adjuster and the outer ring can just be taken off, but this is only necessary if the grinder has to be completely replaced. Be careful and do not use excessive force.
    • Beyond the white ring with the holes there is a small springloaded ball (3.2 mm diameter). It ensures that the ring clicks into place, hence the click. Be careful, it can fall out and get lost.
    • The following pictures show a grinder of a Jura and there are slight differences. But since the grinder is the same, the repair is basically the same.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
de en
100%
VauWeh님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
작성자
1다른 기여자 명과 함께
VauWeh
회원 가입일: 10/19/15
331,057 평판
안내서 311개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 11
지난 30일: 53
전체 시간: 2,991
