주요 콘텐츠로 건너뛰기
Opening the Column in the Hamilton Galileo
필요한 것
  1. Opening the Column in the Hamilton Galileo, Opening the Column in the Hamilton Galileo: 1 단계, 이미지 1개 중 1개
    • Use a grounding cable and wrist band connected to the GALILEO or other work surface when you are working on the GALILEO.
    • Remove from GALILEO: External mains power supply, Air and oxygen supplies, Patient breathing circuit (for convenience only), Flow Sensor tubes (for convenience only).
  2. Opening the Column in the Hamilton Galileo: 3 단계, 이미지 1개 중 1개
    • Loosen the rear panel of the column by removing the six hexagonal-drive (Allen) screws that hold it in place.
  3. Opening the Column in the Hamilton Galileo: 4 단계, 이미지 2개 중 1개 Opening the Column in the Hamilton Galileo: 4 단계, 이미지 2개 중 2개
    • Without removing any electrical connections, open the left side of the column as wide as practical.
    • This exposes: GALILEO’s internal power supply, The battery fuse, The diagnostic LEDs on the power supply’s main circuit board, and the back up batteries.
    • Make sure no electrical connections are touching the column.
    • Make sure all green/brown grounding (earthing) cables are securely in place.
결론
작성자
1다른 기여자 명과 함께
Ian Van Sciver
회원 가입일: 04/09/20
332 평판
안내서 2개를 작성함
Cal Poly, Team S7-G26, Paton Spring 2020 Cal Poly, Team S7-G26, Paton Spring 2020 회원
CPSU-PATON-S20S7G26
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 8
전체 시간: 207
