주요 콘텐츠로 건너뛰기
Opening the Computer (2006-2008)
필요한 것
  1. Opening the Computer (2006-2008), Opening the Computer (2006-2008): 1 단계, 이미지 1/2 Opening the Computer (2006-2008), Opening the Computer (2006-2008): 1 단계, 이미지 2/2
    • Shut down the computer.
    • Warning: Always shut down the computer before opening it to avoid damaging its internal components or the components you are installing. Do not open the computer or attempt to install items inside it while it is on.
    • Wait 5 to 10 minutes to allow the computer’s internal components to cool.
    • Warning: After you shut down the system, the internal components can be very hot. You must let the computer cool down before continuing.
    • Unplug all external cables from the computer except the power cord.
    • Touch the metal PCI access covers on the back of the computer to discharge any static electricity from your body.
    • Unplug the power cord.
    • Put on an ESD wrist strap.
    Updated to reflect same procedure for all models in range
    DavidM - 답글
  2. Opening the Computer (2006-2008): 2 단계, 이미지 1/1
    • 1) Hold the side access panel and lift the latch on the back of the computer.
    • Warning: The edges of the access panel and the enclosure can be sharp. Be very careful when handling them.
    • 2) Remove the access panel and place it on a flat surface covered by a soft, clean cloth.
    • Replacement Note: Make sure the latch is in the up position before replacing the access panel. If the latch is down, the access panel will not seat correctly in the enclosure.
    Is this the actual width of the drive or the internal layout.
    Stephen - 답글
결론
다른 12명이 해당 안내서를 완성하였습니다.
Joshua Byrne
회원 가입일: 05/03/13
7,725 평판
안내서 10개 작성하였습니다
댓글 2개
Do you have information on  Mac Pro Tower 2008 latch mechanism replacement #.
When can I buy this?
v h - 답글
Hola buenos días. Tengo una y soy de Venezuela me gustaría saber cómo conseguir este procesador Xeon x5492
Videos premium - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 15
30일 전: 84
전체 시간: 9,285
