주요 콘텐츠로 건너뛰기
Opening the Galaxy Watch
필요한 것
  1. Opening the Galaxy Watch, Opening Procedure: 1 단계, 이미지 1/1
    • Remove the four Tri-point #00 screws (4.2 mm length) on the backside of the watch.
  2. Opening the Galaxy Watch: 2 단계, 이미지 1/2 Opening the Galaxy Watch: 2 단계, 이미지 2/2
    • Use an opening tool to get between the back cover and the metal housing of the watch.
    • Carefully pry the plastic back cover open.
    • Don't remove the back cover yet. There is a flex cable running to the core assembly inside.
  3. Opening the Galaxy Watch: 3 단계, 이미지 1/2 Opening the Galaxy Watch: 3 단계, 이미지 2/2
    • Lay down the watch and lift the back cover to access the sensor connector on the motherboard.
  4. Opening the Galaxy Watch: 4 단계, 이미지 1/2 Opening the Galaxy Watch: 4 단계, 이미지 2/2
    • Use a spudger to disconnect the sensor flex cable from the motherboard.
  5. Opening the Galaxy Watch: 5 단계, 이미지 1/3 Opening the Galaxy Watch: 5 단계, 이미지 2/3 Opening the Galaxy Watch: 5 단계, 이미지 3/3
    • Remove the back cover.
    • When closing the watch make sure the rubber gasket is undamaged or replace it with a new one.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
117,781 평판
안내서 188개 작성하였습니다
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,083개 작성하였습니다
댓글 한 개
I got 3 out of 4 screws out 1 screw just won't come out need help
peck24hi.mp - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 54
30일 전: 224
전체 시간: 10,489
