주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Opening the Hood
  1. Opening the Hood, Opening the Hood: 1 단계, 이미지 2개 중 1개 Opening the Hood, Opening the Hood: 1 단계, 이미지 2개 중 2개
    • Locate the hood latch beside the driver's side door, next to the left foot rest.
    • Pull the latch toward you to release the hood.
  2. Opening the Hood: 2 단계, 이미지 2개 중 1개 Opening the Hood: 2 단계, 이미지 2개 중 2개
    • Walk around to the front of the vehicle.
    • Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
    • Once the tab is released, lift the hood up.
  3. Opening the Hood: 3 단계, 이미지 2개 중 1개 Opening the Hood: 3 단계, 이미지 2개 중 2개
    • Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
    • Place the tip of the hood stand into the hole located in the upper left of the hood.
    • You can now let the hood rest on the stand.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Shaun MacDonald
회원 가입일: 10/03/12
2,654 평판
안내서 8개를 작성함
Cal Poly, Team 24-27, Regan Fall 2012 Cal Poly, Team 24-27, Regan Fall 2012 회원
CPSU-REGAN-F12S24G27
4 회원들
안내서 24개를 작성함
1가이드 댓글
Whats next after opening the hood? How to check for the hood latch? Where is it located? Need to check for the cause why the alarm keeps going
off at odd hours. The car has lojack and a car alarm. Changed the FOB key that didnt worked. Manually opened the door with key. Not happening problem still exist. Need help with what other options.
boomanison - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 43
지난 7일: 301
지난 30일: 1,405
전체 시간: 80,447
