이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the hood latch beside the driver's side door, next to the left foot rest.
Pull the latch toward you to release the hood.
Walk around to the front of the vehicle.
Slide your hand under the hood, directly above the Honda emblem. Locate and pull the hood tab to unlock the hood.
Once the tab is released, lift the hood up.
Use your left hand to hold the hood up. Locate the hood stand and pull it out of the clip.
Place the tip of the hood stand into the hole located in the upper left of the hood.
You can now let the hood rest on the stand.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Whats next after opening the hood? How to check for the hood latch? Where is it located? Need to check for the cause why the alarm keeps going
off at odd hours. The car has lojack and a car alarm. Changed the FOB key that didnt worked. Manually opened the door with key. Not happening problem still exist. Need help with what other options.
boomanison - 답글
