주요 콘텐츠로 건너뛰기
Opening the Huawei Watch 3
필요한 것
    • User your fingernail to pull the small metal pin on each wrist band towards the inside. This unlocks the wrist bands from the body of the watch.
    • Remove the wrist bands.
  1. Opening the Huawei Watch 3, Remove the four Torx screws: 2 단계, 이미지 1/1
    • Use a Torx T3 screwdriver to remove the four 4 mm-long screws on the back of the Huawei Watch 3.
  2. Opening the Huawei Watch 3, Pry the back cover open: 3 단계, 이미지 1/3 Opening the Huawei Watch 3, Pry the back cover open: 3 단계, 이미지 2/3 Opening the Huawei Watch 3, Pry the back cover open: 3 단계, 이미지 3/3
    • Locate the small notch at the top of the back cover.
    • Use a Jimmy to pry open the back cover by twisting it.
    • Using a sharp metal tool might cause cosmetic damage to the watch case. Covering the tool with a nitril glove can minimize the damage.
    • Don’t remove the back cover just yet. It is still connected to the motherboard with a flex cable.
  3. Opening the Huawei Watch 3, Loosen the back cover gasket: 4 단계, 이미지 1/2 Opening the Huawei Watch 3, Loosen the back cover gasket: 4 단계, 이미지 2/2
    • Insert the tip of an opening pick between the back cover and the case.
    • Slide the opening pick around the back cover to loosen the gasket from the back cover.
  4. Opening the Huawei Watch 3, Lift the back cover: 5 단계, 이미지 1/3 Opening the Huawei Watch 3, Lift the back cover: 5 단계, 이미지 2/3 Opening the Huawei Watch 3, Lift the back cover: 5 단계, 이미지 3/3
    • There is a ribbon cable running from the back cover to the motherboard.
    • Use an opening pick or your fingers to carefully lift the back cover open.
    • Flip the back cover open away from the crown.
    • You can prop up the back cover to minimize the stress on the ribbon cable.
  5. Opening the Huawei Watch 3, Remove the battery bracket screw: 6 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the battery bracket.
  6. Opening the Huawei Watch 3, Remove the battery bracket: 7 단계, 이미지 1/3 Opening the Huawei Watch 3, Remove the battery bracket: 7 단계, 이미지 2/3 Opening the Huawei Watch 3, Remove the battery bracket: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • User a pair of tweezers to lift the top of the battery bracket free from its screw socket.
    • Unhook the opposite side of the bracket and remove it.
  7. Opening the Huawei Watch 3, Unplug the battery connector: 8 단계, 이미지 1/2 Opening the Huawei Watch 3, Unplug the battery connector: 8 단계, 이미지 2/2
    • Use the tip of a spudger to pry up and disconnect the battery connector.
    • The battery connector is the smallest of the three connectors.
  8. Opening the Huawei Watch 3, Remove the sensor bracket screw: 9 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the 2.9 mm-long screw from the sensor bracket.
  9. Opening the Huawei Watch 3, Remove the sensor bracket: 10 단계, 이미지 1/3 Opening the Huawei Watch 3, Remove the sensor bracket: 10 단계, 이미지 2/3 Opening the Huawei Watch 3, Remove the sensor bracket: 10 단계, 이미지 3/3
    • User a pair of tweezers to move the top of the sensor bracket free from a small latch near the case by rotating in inwards.
  10. Opening the Huawei Watch 3, Unplug the sensor connector: 11 단계, 이미지 1/3 Opening the Huawei Watch 3, Unplug the sensor connector: 11 단계, 이미지 2/3 Opening the Huawei Watch 3, Unplug the sensor connector: 11 단계, 이미지 3/3
    • Use the tip of a spudger to pry up and disconnect the sensor connector.
    • Remove the back cover.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our https://www.ifixit.com/Answers/Device/Hu... for help.
다른 한 분이 해당 안내서를 완성하였습니다.
Tobias Isakeit
회원 가입일: 03/31/14
119,191 평판
안내서 189개 작성하였습니다
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer 회원
Business
1 회원
안내서 1,092개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 42
30일 전: 139
전체 시간: 1,560
