주요 콘텐츠로 건너뛰기
Opening the Sirius SP-B1 Sportster Boombox
필요한 것
  1. Opening the Sirius SP-B1 Sportster Boombox, Outer Case: 1 단계, 이미지 1/1
    • Begin by unscrewing the four recessed screws in the rear of the boombox. They don't seem to be magnetic, and they may not pop out immediately.
  2. Opening the Sirius SP-B1 Sportster Boombox: 2 단계, 이미지 1/3 Opening the Sirius SP-B1 Sportster Boombox: 2 단계, 이미지 2/3 Opening the Sirius SP-B1 Sportster Boombox: 2 단계, 이미지 3/3
    • Next, you will need to remove the mesh that covers the speakers. Using the flathead screwdriver, start prying near the top or bottom of the mesh, near the center. The 'corners' come up more easily. Once you have part of the mesh pulled out, go around the outside and use indents in the mesh to pry it out. Try not to bend the mesh very much.
  3. Opening the Sirius SP-B1 Sportster Boombox: 3 단계, 이미지 1/1
    • There are screws now accessible near the bottom of each side under the mesh, near the center of the boombox. Once you remove these, the faceplate will come right off.
  4. Opening the Sirius SP-B1 Sportster Boombox: 4 단계, 이미지 1/3 Opening the Sirius SP-B1 Sportster Boombox: 4 단계, 이미지 2/3 Opening the Sirius SP-B1 Sportster Boombox: 4 단계, 이미지 3/3
    • Now you can get to some of the electronic components. Only eight screws separate you from the inside of the boombox. Undo the screws and fix up the inside to your heart's content.
결론
다른 2명이 해당 안내서를 완성하였습니다.
sonori
회원 가입일: 06/13/11
195 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 1,158
