주요 콘텐츠로 건너뛰기
Oppo X9000 Chassis Replacement
필요한 것
  1. Oppo X9000 Chassis Replacement, Removing the Back Cover: 1 단계, 이미지 1/2 Oppo X9000 Chassis Replacement, Removing the Back Cover: 1 단계, 이미지 2/2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
  2. Oppo X9000 Chassis Replacement, Removing the Battery: 2 단계, 이미지 1/1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
  3. Oppo X9000 Chassis Replacement, Remove the Back Panel Screws: 3 단계, 이미지 1/2 Oppo X9000 Chassis Replacement, Remove the Back Panel Screws: 3 단계, 이미지 2/2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
  4. Oppo X9000 Chassis Replacement, Remove the Rubber Stoppers: 4 단계, 이미지 1/2 Oppo X9000 Chassis Replacement, Remove the Rubber Stoppers: 4 단계, 이미지 2/2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
  5. Oppo X9000 Chassis Replacement, Remove the Newly Exposed Screws: 5 단계, 이미지 1/1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
  6. Oppo X9000 Chassis Replacement, Lift off the Back Panel: 6 단계, 이미지 1/2 Oppo X9000 Chassis Replacement, Lift off the Back Panel: 6 단계, 이미지 2/2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
결론
다른 4명이 해당 안내서를 완성하였습니다.
James Kragh
회원 가입일: 10/14/14
1,602 평판
안내서 5개 작성하였습니다
Cal Poly, Team 4-45, Amido Fall 2014 Cal Poly, Team 4-45, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G45
5 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 1,850
