주요 콘텐츠로 건너뛰기
Oppo X9000 Front Facing Camera Replacement
필요한 것
  1. Oppo X9000 Front Facing Camera Replacement, Removing the Back Cover: 1 단계, 이미지 1/2 Oppo X9000 Front Facing Camera Replacement, Removing the Back Cover: 1 단계, 이미지 2/2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
  2. Oppo X9000 Front Facing Camera Replacement, Removing the Battery: 2 단계, 이미지 1/1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
  3. Oppo X9000 Front Facing Camera Replacement, Remove the Back Panel Screws: 3 단계, 이미지 1/2 Oppo X9000 Front Facing Camera Replacement, Remove the Back Panel Screws: 3 단계, 이미지 2/2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
  4. Oppo X9000 Front Facing Camera Replacement, Remove the Rubber Stoppers: 4 단계, 이미지 1/2 Oppo X9000 Front Facing Camera Replacement, Remove the Rubber Stoppers: 4 단계, 이미지 2/2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
  5. Oppo X9000 Front Facing Camera Replacement, Remove the Newly Exposed Screws: 5 단계, 이미지 1/1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
  6. Oppo X9000 Front Facing Camera Replacement, Lift off the Back Panel: 6 단계, 이미지 1/2 Oppo X9000 Front Facing Camera Replacement, Lift off the Back Panel: 6 단계, 이미지 2/2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
  7. Oppo X9000 Front Facing Camera Replacement, Remove the Power Button Bracket: 7 단계, 이미지 1/1
    • Use the sharp end of the spudger to pry the power button bracket from the side of the rear case.
  8. Oppo X9000 Front Facing Camera Replacement, Let the Button Fall Out: 8 단계, 이미지 1/1
    • Rotate the phone onto its side so that the power button falls out with ease.
    • Make sure not to lose the power button.
  9. Oppo X9000 Front Facing Camera Replacement, Remove the Volme Button Bracket: 9 단계, 이미지 1/1
    • Use the sharp end of the spudger to pry the volume button bracket from the side of the rear case.
  10. Oppo X9000 Front Facing Camera Replacement, Let the Button Fall Out: 10 단계, 이미지 1/1
    • Rotate the phone onto its side so that the volume button falls out with ease.
    • Make sure not to lose the volume button.
  11. Oppo X9000 Front Facing Camera Replacement, Remove the Black Screws: 11 단계, 이미지 1/2 Oppo X9000 Front Facing Camera Replacement, Remove the Black Screws: 11 단계, 이미지 2/2
    • The motherboard is split into two different chips. The large chip is located above where the battery rests and the smaller chip is located below it.
    • Remove the three 3.6 mm Phillip's screws on the motherboard.
    • A small silver piece of metal is connected to the lowest screw and may fall off. This metal holds the WiFi antenna in place and should not be lost; although the phone operates just fine without it.
  12. Oppo X9000 Front Facing Camera Replacement, Disconnect the Motherboard: 12 단계, 이미지 1/3 Oppo X9000 Front Facing Camera Replacement, Disconnect the Motherboard: 12 단계, 이미지 2/3 Oppo X9000 Front Facing Camera Replacement, Disconnect the Motherboard: 12 단계, 이미지 3/3
    • Using the flat end of the spudger, pry the four tape connectors straight up out of their respective motherboard sockets.
  13. Oppo X9000 Front Facing Camera Replacement: 13 단계, 이미지 1/2 Oppo X9000 Front Facing Camera Replacement: 13 단계, 이미지 2/2
    • This connection is a little bit more tricky to remove. Follow these directions carefully to avoid damaging the device.
    • On the right side, there are two motherboard connections hidden underneath the motherboard. For these, insert the spudger in between the motherboard and the connection and rotate the spudger in a rocking motion until the two cables are disconnected from the motherboard.
  14. Oppo X9000 Front Facing Camera Replacement: 14 단계, 이미지 1/2 Oppo X9000 Front Facing Camera Replacement: 14 단계, 이미지 2/2
    • Like the last step, this connection is tricky to remove. Please pay close attention to the guide to avoid damaging your device.
    • On the bottom right only one connection is visible, however an additional connection is hidden underneath the first. To safely disconnect both, first unplug the visible connection then lift its tape up to expose the second socket. Similarly disconnect the second tape.
  15. Oppo X9000 Front Facing Camera Replacement, Disconnect the WiFi Antenna: 15 단계, 이미지 1/2 Oppo X9000 Front Facing Camera Replacement, Disconnect the WiFi Antenna: 15 단계, 이미지 2/2
    • With your fingers, gently pull upwards on the WiFi antenna near the connection on the smaller motherboard until the antenna is no longer connected to the bottom motherboard.
  16. Oppo X9000 Front Facing Camera Replacement, Remove the Small Motherboard: 16 단계, 이미지 1/1
    • Use the spudger to carefully pry the small motherboard off of the phone.
    • Start from the sides of the lower motherboard closest to the charging port. Carefully pry the motherboard off until it is no longer connected to the phone.
  17. Oppo X9000 Front Facing Camera Replacement, Remove the Big Motherboard: 17 단계, 이미지 1/1
    • Use the spudger to carefully pry the bigger motherboard off of the phone.
    • Start from the top of the large motherboard. Carefully pry the motherboard off until it is no longer connected to the phone.
  18. Oppo X9000 Front Facing Camera Replacement, Remove the Front Facing Camera: 18 단계, 이미지 1/1
    • Turn the large motherboard chip around so that you are facing the back of the chip.
    • Use the flat end of the spudger to disconnect the cable that attaches the camera to the large motherboard chip.
결론
다른 9명이 해당 안내서를 완성하였습니다.
James Kragh
회원 가입일: 10/14/14
1,602 평판
안내서 5개 작성하였습니다
Cal Poly, Team 4-45, Amido Fall 2014 Cal Poly, Team 4-45, Amido Fall 2014 회원
CPSU-AMIDO-F14S4G45
5 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 16
전체 시간: 3,776
