주요 콘텐츠로 건너뛰기
Optical drive Replacement
필요한 것
  1. Optical drive Replacement, Optical drive: 1 단계, 이미지 1/1
    • First make sure the laptop is off and closed.
  2. Optical drive Replacement: 2 단계, 이미지 1/1
    • Unlock the battery and push the release lever to remove the battery from the laptop.
  3. Optical drive Replacement: 3 단계, 이미지 1/2 Optical drive Replacement: 3 단계, 이미지 2/2
    • Unscrew the four screws to remove the hard drive cover.
    • Remove these two screws to loosen the hard drive.
    • Gently slide the hard drive out.
    • The hard drive is missing from this device. (Only cover is shown)
  4. Optical drive Replacement: 4 단계, 이미지 1/1
    • Remove all the screws that hold the plastic bottom on. There are some more screws that can't be seen in the photo.
  5. Optical drive Replacement: 5 단계, 이미지 1/1
    • Gently pry up the plastic bottom and if it feels like it is resisting check the surrounding areas for more screws.
  6. Optical drive Replacement: 6 단계, 이미지 1/1
    • Now that the backing plate is off make sure to be careful of the Motherboard and its components from being damaged. From here on out it is recommended that you wear an anti static bracelet or at the very least touching something metal to remove any static electricity that you may have built up.
  7. Optical drive Replacement: 7 단계, 이미지 1/2 Optical drive Replacement: 7 단계, 이미지 2/2
    • There will be a couple more screw holding in the CD tray and once you remove them the CD tray will simply slide out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Eric Martinez
회원 가입일: 02/14/17
637 평판
안내서 6개 작성하였습니다
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 회원
USFT-REMMELL-S17S20G5
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 10
전체 시간: 761
