주요 콘텐츠로 건너뛰기
Optoma HD20 Focal Lens Replacement
필요한 것
  1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: 1 단계, 이미지 1/2 Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: 1 단계, 이미지 2/2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Optoma HD20 Focal Lens Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Optoma HD20 Focal Lens Replacement: 3 단계, 이미지 1/1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Optoma HD20 Focal Lens Replacement: 4 단계, 이미지 1/1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
  5. Optoma HD20 Focal Lens Replacement, Focal Lens: 5 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
  6. Optoma HD20 Focal Lens Replacement: 6 단계, 이미지 1/1
    • Remove the focal lens by twisting it clockwise until it comes off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Trever
회원 가입일: 01/22/15
1,264 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 회원
CPSU-MANESS-W15S21G23
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 11
전체 시간: 4,338
