주요 콘텐츠로 건너뛰기
Optoma HD20 Light Bulb Replacement
필요한 것
  1. Optoma HD20 Light Bulb Replacement, Rear Panel: 1 단계, 이미지 1/2 Optoma HD20 Light Bulb Replacement, Rear Panel: 1 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to loosen the screws that secure the panel on the bottom of the Optoma HD20.
  2. Optoma HD20 Light Bulb Replacement: 2 단계, 이미지 1/1
    • Lift the panel off of the device.
  3. Optoma HD20 Light Bulb Replacement, Light Bulb Casing: 3 단계, 이미지 1/1
    • Use a Phillips #1 screwdriver to loosen the two screws securing the black casing.
    • The screws don't come out all the way.
  4. Optoma HD20 Light Bulb Replacement: 4 단계, 이미지 1/3 Optoma HD20 Light Bulb Replacement: 4 단계, 이미지 2/3 Optoma HD20 Light Bulb Replacement: 4 단계, 이미지 3/3
    • Remove the light bulb casing from the device.
    • Steps 5-9 are unnecessary if the replacement light bulb comes with housing.
  5. Optoma HD20 Light Bulb Replacement, Light Bulb: 5 단계, 이미지 1/1
    • Remove the three 4.5 mm screws on the light bulb case.
  6. Optoma HD20 Light Bulb Replacement: 6 단계, 이미지 1/1
    • Carefully remove the light bulb insulator from the light bulb casing.
  7. Optoma HD20 Light Bulb Replacement: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Gently pull the wires off of the pins using tweezers.
  8. Optoma HD20 Light Bulb Replacement: 8 단계, 이미지 1/1
    • Remove the 4 screws on the back of the light bulb casing using a Phillips #1 screwdriver.
  9. Optoma HD20 Light Bulb Replacement: 9 단계, 이미지 1/2 Optoma HD20 Light Bulb Replacement: 9 단계, 이미지 2/2
    • Remove the casing, then gently pull out the old light bulb and replace it with the new one.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Trever
회원 가입일: 01/22/15
1,264 평판
안내서 6개 작성하였습니다
Cal Poly, Team 21-23, Maness Winter 2015 Cal Poly, Team 21-23, Maness Winter 2015 회원
CPSU-MANESS-W15S21G23
4 회원들
안내서 6개 작성하였습니다
댓글 5개
I recently replaced my bulb for the third time and the insulator had grown brittle I am guessing from the heat and it broke. I can't seem to find this part for sale anywhere. Does anyone know if is possible to purchase it?
Thomas - 답글
The screws in step 8 are extremely hard to get off. I went and bought proper screwdrivers before even attempting since theyre small, but in a day I've only managed to get one off and I'm having to resort to other tactics, even using a drill to just grind the heads off.
dv01_ - 답글
king@okinlamps.com
Need LAD60 20PCS
kingshen92 - 답글
The manual says the new light won’t come back on until a lamp reset I’d done via menu , but how can you see the text if the light isn’t on?????
Taringajohn - 답글
my hd 20 projects dull images i recently replaced my bulb for the first time successfully and i followed as per menu trying to bulb reset but it is not working and still image is dull how to solve the problem
kumar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 71
전체 시간: 11,650
