주요 콘텐츠로 건너뛰기
Oral-B Vitality Battery Replacement
필요한 것
  1. Oral-B Vitality Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Oral-B Vitality Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Oral-B Vitality Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Pull off head, and use pliers to remove the white cap. Pull out the circuit core.
  2. Oral-B Vitality Battery Replacement: 2 단계, 이미지 2개 중 1개 Oral-B Vitality Battery Replacement: 2 단계, 이미지 2개 중 2개
    • De-solder in these four (4) locations.
    • The two (2) motor connections
    • The Positive (+) side of the battery
    • The Negative (-) side of the battery
  3. Oral-B Vitality Battery Replacement: 3 단계, 이미지 2개 중 1개 Oral-B Vitality Battery Replacement: 3 단계, 이미지 2개 중 2개
    • De-Solder lower battery connection terminal. Bend back battery terminal to clear circuit board.
  4. Oral-B Vitality Battery Replacement: 4 단계, 이미지 1개 중 1개
    • De-Solder the three (3) upper terminals from the circuit board.
  5. Oral-B Vitality Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Use plastic prying tools to carefully pry off the circuit board. (Utilize metal spedger as a last resort)
    • There is a white tab that goes through the board, be careful when removing the circuit board.
  6. Oral-B Vitality Battery Replacement: 6 단계, 이미지 2개 중 1개 Oral-B Vitality Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Pull the circuit board and battery assembly out. Then proceed to remove the battery from the circuit board
  7. Oral-B Vitality Battery Replacement: 7 단계, 이미지 1개 중 1개
    • When re-installing battery, remember to bend down lower terminal. And the negative (-) terminal is closest to the copper wires
    • Ensure you recharge the toothbrush after the repair. Even if the replacement battery is already fully charged, the toothbrush will fail to power on if you don’t recharge the toothbrush.
결론
To reassemble your device, follow these instructions in reverse order. Remember to apply just enough solder to re-attach the terminals.
다른 17명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Miles Gunty
회원 가입일: 11/07/17
540 평판
안내서 1개를 작성함
IUPUI, Team S2-G1, Harley Fall 2017 IUPUI, Team S2-G1, Harley Fall 2017 회원
IUPUI-HARLEY-F17S2G1
3 회원들
안내서 9개를 작성함
댓글 9개
This is very easy to do. I had no problems following your instructions.
Ian Bowker - 답글
Thanks.
Is this a regular rechargeable AA?
Thanks again.
Stephen Shaw - 답글
The original battery is a NiCd with tabs. I just spot welded tabs onto a standard AA NiMH battery and it worked fine.
T C -
Thanks.
I did fix an Oral B Braun PRO timer (2022) and the only part that is different is the head. It has two nail presses inside, one at the switch side and the other at the opposite side, that are very difficult to lose.
Peter M. - 답글
댓글 쓰기
조회 통계:
지난 24시간: 18
지난 7일: 179
지난 30일: 728
전체 시간: 51,768
