주요 콘텐츠로 건너뛰기
Oral-B Vitality Power Button Replacement
필요한 것
  1. Oral-B Vitality Power Button Replacement, Power Button: 1 단계, 이미지 3개 중 1개 Oral-B Vitality Power Button Replacement, Power Button: 1 단계, 이미지 3개 중 2개 Oral-B Vitality Power Button Replacement, Power Button: 1 단계, 이미지 3개 중 3개
    • Using the pliers, rotate the head base 90 degrees counterclockwise and remove core from the handle.
  2. Oral-B Vitality Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the 4 terminals connecting the power button to the circuit board.
  3. Oral-B Vitality Power Button Replacement: 3 단계, 이미지 3개 중 1개 Oral-B Vitality Power Button Replacement: 3 단계, 이미지 3개 중 2개 Oral-B Vitality Power Button Replacement: 3 단계, 이미지 3개 중 3개
    • Desolder the 4 terminals and remove the old button.
    • Remove as much of the old solder as possible.
  4. Oral-B Vitality Power Button Replacement: 4 단계, 이미지 1개 중 1개
    • Attach the new button by soldering the 4 terminals with new solder.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Grady Bennett
회원 가입일: 11/07/17
506 평판
안내서 2개를 작성함
IUPUI, Team S2-G1, Harley Fall 2017 IUPUI, Team S2-G1, Harley Fall 2017 회원
IUPUI-HARLEY-F17S2G1
3 회원들
안내서 9개를 작성함
댓글 5개
In my case no need to change the button, just redo the solder and this is it.
the vibration has damaged the solder.
Al kri - 답글
If you try to unsolder the battery it has some protection and it won't work anymore
Gigi Kent - 답글
Before unsoldering the button, you can understand if it is good or not just bypassing it with a wire: with a copper wire you can touch two pins of the button (one on the right side, on on the left side); if the toothbrush starts and stop on each touch of the wire, the problem is the button. I recognize the problem in this way.
Manolo Cerello - 답글
True except if the switch is permanently “on”. I think that was my case. Replacing the switch fixed the issue.
Mumble Tim -
In my case the inside of the case of the toothbrush where the cover for the start button is, was worn. I cut 3 - 3/16" squares of electrical tape and placed it on top of the start switch. This filled the gap where the worn material was and enabled the switch to be activated easier. I also noticed that some moisture was inside the case of the toothbrush, so I coated the metal shaft protruding from the toothbrush, and the o ring of the cap with some water proof grease, Vaseline.
Robert Carl - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 37
지난 30일: 125
전체 시간: 11,575
