주요 콘텐츠로 건너뛰기
Orbic Wonder Battery Replacement
필요한 것
  1. Orbic Wonder Battery Replacement, Battery: 1 단계, 이미지 1/3 Orbic Wonder Battery Replacement, Battery: 1 단계, 이미지 2/3 Orbic Wonder Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove two 2mm TR9 Torx screws from the bottoms of the device.
  2. Orbic Wonder Battery Replacement: 2 단계, 이미지 1/3 Orbic Wonder Battery Replacement: 2 단계, 이미지 2/3 Orbic Wonder Battery Replacement: 2 단계, 이미지 3/3
    • There is a border between the black phone backing and the silver screen.
    • Place the Jimmy in this border, and cautiously torque it back and forth to part the two halves.
    • When the halves are parted correctly, the gap should look like this.
    • Be careful to avoid damaging any connecting circuitry between the two halves.
  3. Orbic Wonder Battery Replacement: 3 단계, 이미지 1/3 Orbic Wonder Battery Replacement: 3 단계, 이미지 2/3 Orbic Wonder Battery Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Anti-Static Wrist Strap
    $7.95
    구매
    • Before continuing, tighten the anti-static wrist strap around your wrist and connect the alligator clips to a metal portion of the phone.
    • On the upper right side, there is a black ribbon cable in the shape of an “L”. Remove the single 1 mm Phillips #000 screw on the left side of the ribbon cable.
  4. Orbic Wonder Battery Replacement: 4 단계, 이미지 1/3 Orbic Wonder Battery Replacement: 4 단계, 이미지 2/3 Orbic Wonder Battery Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    $3.99
    구매
    • Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
    • Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
  5. Orbic Wonder Battery Replacement: 5 단계, 이미지 1/3 Orbic Wonder Battery Replacement: 5 단계, 이미지 2/3 Orbic Wonder Battery Replacement: 5 단계, 이미지 3/3
    • There is a black flap on the bottom of the battery.
    • Using your fingers, pinch this flap and carefully pull the battery up and out of the phone.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Grant Adler
회원 가입일: 09/17/19
859 평판
안내서 5개 작성하였습니다
댓글 3개
where do you buy the replacement battery at ?
ricotoomo - 답글
Where can I buy a replacement battery
Robert Smith -
Thank you big help your smart
gansterms123 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 14
30일 전: 55
전체 시간: 7,092
