필요한 것
Remove the two 2 mm TR9 Torx head screws at the bottom of the device. The screws are located on the right and left side of the charging port.
이 단계에 사용된 도구:Tweezers$3.99
Using a pair of angled tweezers, remove the metal plate protector.
Unplug the connector with a pair of tweezers.
Unplug the second connector with a pair of tweezers.
거의 끝나갑니다!
결론
다른 3명이 해당 안내서를 완성하였습니다.
