소개
This guide covers the steps to remove and replace the broken screen on your Orbic wonder. Some steps are repeated, as this is a guide made up of other guides.
필요한 것
이 단계에 사용된 도구:Tweezers$3.99
Use a pair of angled tweezers to carefully remove the metal casing of the ribbon cable.
Use a pair of angled tweezers to detach the black ribbon cable. This is done to unplug the battery.
이 단계에 사용된 도구:Anti-Static Wrist Strap$7.95
Remove the anti-static wrist strap.
Use the Phillips #000 screwdriver to remove the five black 2 mm screws.
Use the Phillips #000 screwdriver to remove the two grey 2 mm screws.
Use a pair of angled tweezers to remove the speaker housing.
Detach the metal casing at the bottom of the phone.
Unplug the cable connector.
Use a pair of angled tweezers to unplug the black wire.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
how can and or can I swap media files from orbic wonder “with damaged screen “ to a gaxalxy a01
