주요 콘텐츠로 건너뛰기
Ordro HDV-D395 Back Case Replacement
필요한 것
  1. Ordro HDV-D395 Back Case Replacement, Back Case: 1 단계, 이미지 1/2 Ordro HDV-D395 Back Case Replacement, Back Case: 1 단계, 이미지 2/2
    • Pull the slider labeled open, on the bottom right, to unlock the battery.
  2. Ordro HDV-D395 Back Case Replacement: 2 단계, 이미지 1/1
    • Pull battery out of slot.
  3. Ordro HDV-D395 Back Case Replacement: 3 단계, 이미지 1/1
    • Unfold the screen from the side of the camera.
  4. Ordro HDV-D395 Back Case Replacement: 4 단계, 이미지 1/1
    • Twist the screen so that the screen is facing downward.
  5. Ordro HDV-D395 Back Case Replacement: 5 단계, 이미지 1/2 Ordro HDV-D395 Back Case Replacement: 5 단계, 이미지 2/2
    • Unscrew the four screws on the side (length 2.9 mm) with a JIS #000 screwdriver.
    • Unscrew the three screws on the bottom (length 7.7 mm) with a JIS #000 screwdriver.
  6. Ordro HDV-D395 Back Case Replacement: 6 단계, 이미지 1/1
    • Pull apart the camera into two pieces by pulling the side with the screen away from the main body of the camera.
  7. Ordro HDV-D395 Back Case Replacement: 7 단계, 이미지 1/2 Ordro HDV-D395 Back Case Replacement: 7 단계, 이미지 2/2
    • Unscrew the two screws (size 4.75 mm) with a PH #00 screwdriver.
    • Unscrew the screw (size 7.65 mm) with a PH #00 screwdriver.
  8. Ordro HDV-D395 Back Case Replacement: 8 단계, 이미지 1/1
    • Take the back case off by pulling it away from the main body.
    • Be careful not to tear the white strap that connects the back case to the main body.
  9. Ordro HDV-D395 Back Case Replacement: 9 단계, 이미지 1/1
    • Unscrew all four screws (length 4.13 mm) on the inside of the case with a PH #00 screwdriver.
  10. Ordro HDV-D395 Back Case Replacement: 10 단계, 이미지 1/1
    • Pull the board away from the back case.
결론
Mostafa Abdulaleem
회원 가입일: 11/05/18
181 평판
안내서 1개 작성함
IUPUI, Team S1-G3, Baechle Fall 2018 IUPUI, Team S1-G3, Baechle Fall 2018 회원
IUPUI-BAECHLE-F18S1G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 10
전체 시간: 300
