주요 콘텐츠로 건너뛰기
Oregon Scientific Meep! 4.0 Motherboard Replacement
필요한 것
  1. Oregon Scientific Meep! 4.0 Motherboard Replacement, Oregon Scientific Meep! 4.0 Disassembly: 1 단계, 이미지 1/1
    • Use a screwdriver to remove the four 7.0 mm Philips #00 screws from the back of the device.
  2. Oregon Scientific Meep! 4.0 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use a plastic opening tool to detach the clips on the inside of the device.
  3. Oregon Scientific Meep! 4.0 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/2 Oregon Scientific Meep! 4.0 Motherboard Replacement, Motherboard: 3 단계, 이미지 2/2
    • Use a soldering station to disconnect any wires attached to the motherboard.
  4. Oregon Scientific Meep! 4.0 Motherboard Replacement: 4 단계, 이미지 1/1
    • Use a screwdriver to unscrew the three 4.0 mm Philips #00 screws holding the motherboard in place.
  5. Oregon Scientific Meep! 4.0 Motherboard Replacement: 5 단계, 이미지 1/1
    • Use a plastic opening tool to release the ribbon cables surrounding the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Lauren Milici
회원 가입일: 09/21/15
216 평판
안내서 2개 작성하였습니다
University of Tampa, Team 1-3, Whiteside Fall 2015 University of Tampa, Team 1-3, Whiteside Fall 2015 회원
UT-WHITESIDE-F15S1G3
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 261
