주요 콘텐츠로 건너뛰기
Oregon Scientific Meep! X2 Cameras Replacement
필요한 것
  1. Oregon Scientific Meep! X2 Cameras Replacement, Rear Casing: 1 단계, 이미지 1/1
    • Remove the orange covers from the left and right sides of the device by sliding up against the tabs.
  2. Oregon Scientific Meep! X2 Cameras Replacement: 2 단계, 이미지 1/3 Oregon Scientific Meep! X2 Cameras Replacement: 2 단계, 이미지 2/3 Oregon Scientific Meep! X2 Cameras Replacement: 2 단계, 이미지 3/3
    • You can remove the rear casing by unscrewing all six phillips #00(3.5mm x 4.5mm)screws from the left and right side of the device.
  3. Oregon Scientific Meep! X2 Cameras Replacement: 3 단계, 이미지 1/3 Oregon Scientific Meep! X2 Cameras Replacement: 3 단계, 이미지 2/3 Oregon Scientific Meep! X2 Cameras Replacement: 3 단계, 이미지 3/3
    • Use the plastic opening tools to undo the clips around the edges of the device.
  4. Oregon Scientific Meep! X2 Cameras Replacement, Cameras: 4 단계, 이미지 1/2 Oregon Scientific Meep! X2 Cameras Replacement, Cameras: 4 단계, 이미지 2/2
    • Slip the plastic opening tool under the white, square enclosure of the camera and lift upward to unhook the camera unit from the motherboard.
  5. Oregon Scientific Meep! X2 Cameras Replacement: 5 단계, 이미지 1/2 Oregon Scientific Meep! X2 Cameras Replacement: 5 단계, 이미지 2/2
    • Pry the second camera out of its slot with one of the plastic opening tools.
    • Be sure to undo the black adhesive foam from the metal casing in order to remove the camera properly.
  6. Oregon Scientific Meep! X2 Cameras Replacement: 6 단계, 이미지 1/1
    • Release the black security clip on the ribbon cable with your plastic opening tool.
    • Gently disconnect the gold ribbon cable from the motherboard. The two cameras will remain attached to the ribbon cable.
결론
J'mel Henneman
회원 가입일: 01/20/15
864 평판
안내서 8개 작성하였습니다
USF Tampa, Team 9-1, Blackwell Winter 2015 USF Tampa, Team 9-1, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G1
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 220
