주요 콘텐츠로 건너뛰기
Oregon Scientific RM318PA A/C Power Adapter Replacement
  1. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter: 1 단계, 이미지 1/2 Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter: 1 단계, 이미지 2/2
    • To access the A/C Power Adapter connection, remove the battery cover, located on the back of the clock.
  2. Oregon Scientific RM318PA A/C Power Adapter Replacement, Battery Compartment Cover: 2 단계, 이미지 1/2 Oregon Scientific RM318PA A/C Power Adapter Replacement, Battery Compartment Cover: 2 단계, 이미지 2/2
    • To remove the battery compartment cover, slide the cover up towards the top of the clock while applying slight pressure.
  3. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Socket: 3 단계, 이미지 1/1
    • Gently pull the A/C Power Adapter from the socket, to the left of the batteries.
  4. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Tip: 4 단계, 이미지 1/1
    • To plug in the A/C Power Adapter, insert the tip into the socket, located to the left of the batteries, and press firmly.
    • Be sure that you are inserting an A/C Power Adapter and not a D/C Power Adapter. Inserting the improper cord could cause damage to the device.
  5. Oregon Scientific RM318PA A/C Power Adapter Replacement, A/C Power Adapter Cord: 5 단계, 이미지 1/1
    • Once the A/C Power Adapter tip is inserted in the socket, guide the cord through a notch directly below.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Maxine Holden
회원 가입일: 10/27/14
476 평판
안내서 4개 작성하였습니다
댓글 4개
i need operating manual for model no.rm318pa.please send to…gjgeoff1@outlook.fr
jean-guy geoffroy - 답글
i need operating manuel
jean-guy geoffroy -
When you say make sure to insert AC power adapter what do you mean. It clearly says DC3V on the clock. Could you post the picture of the adapter without cord over the label?
Alex Olekh - 답글
Alex! Yes, right you are! DC not AC and Oregon Scientific will not answer my email requests. I am !#^&@@!
Ty Ford - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 26
전체 시간: 3,384
