주요 콘텐츠로 건너뛰기
Oregon Scientific RM318PA Lens Replacement
필요한 것
  1. Oregon Scientific RM318PA Lens Replacement, A/C Adapter: 1 단계, 이미지 3개 중 1개 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: 1 단계, 이미지 3개 중 2개 Oregon Scientific RM318PA Lens Replacement, A/C Adapter: 1 단계, 이미지 3개 중 3개
    • Hold clock so the screen is facing away from you.
    • Using your thumbs, push up on battery cover to remove.
    • With your other hand, pull down on the A/C Adapter jack to remove.
  2. Oregon Scientific RM318PA Lens Replacement, Batteries: 2 단계, 이미지 1개 중 1개
    • Remove batteries by pushing a battery toward the spring.
    • Lift battery out at an angle. Repeat with second battery.
  3. Oregon Scientific RM318PA Lens Replacement, Projection Arm: 3 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Projection Arm: 3 단계, 이미지 2개 중 2개
    • Use a Phillips #00 Screwdriver to remove the four (4) screws from the back of the projection arm.
    • Once screws are removed, lift the back up and off of the projection arm.
  4. Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: 4 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Screws Projection Arm: 4 단계, 이미지 2개 중 2개
    • Use a Phillips #00 Screwdriver to remove two (2) screws from back of projection arm.
  5. Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: 5 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Front of the Projection Arm: 5 단계, 이미지 2개 중 2개
    • Use a Plastic Opening Tool to pry open the front of the projection arm casing. Start at the top of the projection arm.
    • Once top is partially open, use a Spudger to pry at the side of the projection arm.
  6. Oregon Scientific RM318PA Lens Replacement, Projection Beam: 6 단계, 이미지 3개 중 1개 Oregon Scientific RM318PA Lens Replacement, Projection Beam: 6 단계, 이미지 3개 중 2개 Oregon Scientific RM318PA Lens Replacement, Projection Beam: 6 단계, 이미지 3개 중 3개
    • Turn the clock on its side. Slide the focus wheel forward with your thumb.
    • The Projection Beam and Focus Wheel Component should now be free of Projection Arm.
    • Hold the Component in one hand and lift the Projection Beam up and away from the Focus Wheel.
  7. Oregon Scientific RM318PA Lens Replacement, The Lens: 7 단계, 이미지 1개 중 1개
    • The Lens is attached to the Focus Knob and is now accessible for replacement purposes.
  8. Oregon Scientific RM318PA Lens Replacement, Tape: 8 단계, 이미지 1개 중 1개
    • Apply tape to the lens for safe removal and prevention of injury.
  9. Oregon Scientific RM318PA Lens Replacement, Focus Knob: 9 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Focus Knob: 9 단계, 이미지 2개 중 2개
    • Detach the focus knob from the internal casing of the lens by removing the screw from the base of the focus knob grip.
    • Pry apart the pieces of casing holding the focus knob in place and remove the knob.
  10. Oregon Scientific RM318PA Lens Replacement, Internal Casing: 10 단계, 이미지 3개 중 1개 Oregon Scientific RM318PA Lens Replacement, Internal Casing: 10 단계, 이미지 3개 중 2개 Oregon Scientific RM318PA Lens Replacement, Internal Casing: 10 단계, 이미지 3개 중 3개
    • Insert the spudger into the opening above the hinge on the side of the casing.
    • Press down firmly until the case opens.
  11. Oregon Scientific RM318PA Lens Replacement, Lens Removal: 11 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Lens Replacement, Lens Removal: 11 단계, 이미지 2개 중 2개
    • Pull apart the casing and gently slide lens from pocket.
    • Be sure to replace with a concave lens.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Maxine Holden
회원 가입일: 10/27/14
491 평판
안내서 4개를 작성함
1가이드 댓글
Hi, I’ve this alarm clock with missing piezo/speaker, can anyone take a picture of the main board showing the pads for it?
Mastto geppetto - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 30
전체 시간: 2,810
