주요 콘텐츠로 건너뛰기
Oregon Scientific RM318PA Power Switch Replacement
필요한 것
  1. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: 1 단계, 이미지 3개 중 1개 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: 1 단계, 이미지 3개 중 2개 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: 1 단계, 이미지 3개 중 3개
    • Hold clock so that the clock face is facing away from you.
    • Using your thumbs, push up on the battery cover.
    • Once battery cover is removed, pull down on AC Adapter Jack.
  2. Oregon Scientific RM318PA Power Switch Replacement, Batteries: 2 단계, 이미지 1개 중 1개
    • Use one hand to stabilize the clock.
    • Using your other hand, push batteries toward spring and pull out at an angle.
  3. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: 3 단계, 이미지 3개 중 1개 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: 3 단계, 이미지 3개 중 2개 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: 3 단계, 이미지 3개 중 3개
    • Use a Plastic Opening Tool to pry off the silver casing on the back.
    • Pry at the top of device.
    • Once the back is open at the top, pry at the side of the device closest to the battery compartment.
    • On/Off switch should come off with casing.
  4. Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: 4 단계, 이미지 2개 중 1개 Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: 4 단계, 이미지 2개 중 2개
    • Insert switch into slot as shown in picture. Push in until you hear a "click."
    • Replace the back of the clock by pressing cover back into place.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Maxine Holden
회원 가입일: 10/27/14
491 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 17
전체 시간: 1,586
