주요 콘텐츠로 건너뛰기
Oreva FX-82MS Battery Replacement
필요한 것
  1. Oreva FX-82MS Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the calculator by pressing the [Shift] button and then press the [AC][OFF] button, (while keeping the [Shift] button pressed down).
  2. Oreva FX-82MS Battery Replacement: 2 단계, 이미지 2개 중 1개 Oreva FX-82MS Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the calculator over so that the back panel faces up.
    • Use a Phillips #0 screwdriver to remove six, 1.2 mm screws starting from the upper right corner.
  3. Oreva FX-82MS Battery Replacement: 3 단계, 이미지 2개 중 1개 Oreva FX-82MS Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the back cover and put it to the side.
  4. Oreva FX-82MS Battery Replacement: 4 단계, 이미지 2개 중 1개 Oreva FX-82MS Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two old batteries from the slots.
    • Be gentle when removing the batteries to avoid damaging the connectors.
  5. Oreva FX-82MS Battery Replacement: 5 단계, 이미지 3개 중 1개 Oreva FX-82MS Battery Replacement: 5 단계, 이미지 3개 중 2개 Oreva FX-82MS Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Place the two new AAA batteries into the calculator, one by one.
    • Be sure that the direction of the + and - signs on your battery match the signs at the bottom of the battery compartment.
    • Place the case on back of the calculator.
  6. Oreva FX-82MS Battery Replacement: 6 단계, 이미지 2개 중 1개 Oreva FX-82MS Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #0 screwdriver to replace the 1.2 mm screws on the back case.
  7. Oreva FX-82MS Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Reset the calculator by pressing [ON].
    • Press the [shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3][ALL] button option.
    • Press [=] [yes] button to agree.
    • Press [AC] key to reset.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Prarthit patel
회원 가입일: 07/02/22
196 평판
안내서 1개를 작성함
1가이드 댓글
Half Display Of Oreva Fx-82 MS Scientific calculator Half Display is not showing How to Fix it?
Devanshu Prajapati - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 21
지난 30일: 108
전체 시간: 3,473
