주요 콘텐츠로 건너뛰기
Origin EON17-S mSATA SSDs Replacement
필요한 것
  1. Origin EON17-S mSATA SSDs Replacement, mSATA SSDs: 1 단계, 이미지 1개 중 1개
    • Opening your computer can be dangerous; give it at least 10 minutes to cool down after shutdown and ensure the power supply and battery are disconnected.
    • Disconnect all peripherals.
    • Disconnect the power cord.
    • Lay the computer upside-down.
  2. Origin EON17-S mSATA SSDs Replacement: 2 단계, 이미지 2개 중 1개 Origin EON17-S mSATA SSDs Replacement: 2 단계, 이미지 2개 중 2개
    • Push both locking tabs inward. One is spring loaded and will need to be held while removing the battery.
    • Remove the battery by pulling up on the tab.
    • To replace the drive in mSATA bay 1, continue to Step 3.
    • To replace the drive in mSATA bay 2, proceed to Step 7.
    • If you are unsure which drive you are replacing, follow all of the remaining steps.
  3. Origin EON17-S mSATA SSDs Replacement: 3 단계, 이미지 3개 중 1개 Origin EON17-S mSATA SSDs Replacement: 3 단계, 이미지 3개 중 2개 Origin EON17-S mSATA SSDs Replacement: 3 단계, 이미지 3개 중 3개
    • Performing the following actions incorrectly can damage your hard drive and could result in lost data. Consider backing up your hard drive(s) before proceeding.
    • Remove the component cover by removing the six screws with a 3/32" screwdriver.
    • Remove the screws from the bottom of the computer.
    • Remove the screws from the back of the computer.
  4. Origin EON17-S mSATA SSDs Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the cover by gently pulling back and up.
  5. Origin EON17-S mSATA SSDs Replacement: 5 단계, 이미지 1개 중 1개
    • An electrostatic discharge could damage your computer. Use an electrostatic wrist strap when working inside the computer.
    • Put on the electrostatic wrist strap and attach the alligator clip to a sturdy piece of metal inside the case.
  6. Origin EON17-S mSATA SSDs Replacement: 6 단계, 이미지 2개 중 1개 Origin EON17-S mSATA SSDs Replacement: 6 단계, 이미지 2개 중 2개
    • You will see the mSATA drive in the lower right hand corner of the component area.
    • Remove the screw on the far right side of the drive.
    • The drive will rise up to an angle.
    • Remove the drive by pulling in the direction the drive is positioned.
  7. Origin EON17-S mSATA SSDs Replacement: 7 단계, 이미지 2개 중 1개 Origin EON17-S mSATA SSDs Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew the two screws holding the hard drive cover to reveal the second mSATA bay.
    • There are two snaps on this cover, pull firmly but carefully to remove it without breaking them.
  8. Origin EON17-S mSATA SSDs Replacement: 8 단계, 이미지 2개 중 1개 Origin EON17-S mSATA SSDs Replacement: 8 단계, 이미지 2개 중 2개
    • Removing the hard drive is necessary to get to the second mSATA bay.
    • Remove the hard drive by sliding it towards you.
    • Once it is free of the port, use a screwdriver to gently pry it from the bay.
  9. Origin EON17-S mSATA SSDs Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the small, silver, rectangular plate below the hard drive bay.
    • Remove the small screw at the front of the plate.
    • Pull the plate up and out.
  10. Origin EON17-S mSATA SSDs Replacement: 10 단계, 이미지 2개 중 1개 Origin EON17-S mSATA SSDs Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the small screw on the upper left of the hard drive.
    • The drive will rise up at an angle.
    • Remove the drive by pulling in the direction the drive is currently positioned.
결론
To reassemble your device, do anything you did in reverse.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Caelan Langdon
회원 가입일: 09/29/15
125 평판
안내서 1개를 작성함
Cal Poly, Team 15-2, Green Fall 2015 Cal Poly, Team 15-2, Green Fall 2015 회원
CPSU-GREEN-F15S15G2
4 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 4,280
