소개
If you have issues with using the joystick, either due to a broken or unresponsive joystick, the joystick module may need to be replaced. This guide will show you how to replace the joystick module.
필요한 것
Remove gimbal from base handle by loosening round plate found at the top of the handle.
Locate four screws directly on top of handle.
Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
Remove the remaining two screws found on the front of the faceplate.
Remove the rest of the face plate shell.
Remove the top left screw on the joystick panel with 00 screwdriver.
Lift the faceplate holding joystick module.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
Well done William! Do you know if the gimbal head of this unit can be reassembled rotated 180 degrees so that it will work with cameras like the Lenovo Mirage VR180 Camera. The Mirage has two forward facing 180 degree cameras that are partially or totally blocked when mounted in the standard configuration. There are other issues that need to be addressed to balance the camera but if the head can be rotated 180 degrees from its standard orientation then the Osmo handle can be held in its normal orientation. Just starting to experiment with this idea and thought you might be able be able to prevent any false starts.
