주요 콘텐츠로 건너뛰기
Osmo Mobile Bluetooth Module Replacement
필요한 것
  1. Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: 1 단계, 이미지 1/2 Osmo Mobile Bluetooth Module Replacement, Osmo Mobile Handle Disassembly: 1 단계, 이미지 2/2
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Bluetooth Module Replacement: 2 단계, 이미지 1/2 Osmo Mobile Bluetooth Module Replacement: 2 단계, 이미지 2/2
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Bluetooth Module Replacement: 3 단계, 이미지 1/1
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Bluetooth Module Replacement: 4 단계, 이미지 1/2 Osmo Mobile Bluetooth Module Replacement: 4 단계, 이미지 2/2
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Bluetooth Module Replacement: 5 단계, 이미지 1/3 Osmo Mobile Bluetooth Module Replacement: 5 단계, 이미지 2/3 Osmo Mobile Bluetooth Module Replacement: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Bluetooth Module Replacement: 6 단계, 이미지 1/3 Osmo Mobile Bluetooth Module Replacement: 6 단계, 이미지 2/3 Osmo Mobile Bluetooth Module Replacement: 6 단계, 이미지 3/3
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
  7. Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: 7 단계, 이미지 1/3 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: 7 단계, 이미지 2/3 Osmo Mobile Bluetooth Module Replacement, Bluetooth Module: 7 단계, 이미지 3/3
    • Locate and remove the black screw found at the base of the grey mounting plate.
    • Remove the grey face plate.
  8. Osmo Mobile Bluetooth Module Replacement: 8 단계, 이미지 1/2 Osmo Mobile Bluetooth Module Replacement: 8 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Open the battery hatch and remove it by using the tweezers to press the hinge into the device.
    • Remove the black screw located underneath where the battery hatch was.
  9. Osmo Mobile Bluetooth Module Replacement: 9 단계, 이미지 1/2 Osmo Mobile Bluetooth Module Replacement: 9 단계, 이미지 2/2
    • Use the spudger to remove the front handle casing by sliding the spudger into the area between the handle grooves.
    • Slide the spudger around the groove to find the 6 clasps that hold the front part of the handle, and unclasp them.
    • Take off the front handle section to reveal the whole interior of the device.
  10. Osmo Mobile Bluetooth Module Replacement: 10 단계, 이미지 1/3 Osmo Mobile Bluetooth Module Replacement: 10 단계, 이미지 2/3 Osmo Mobile Bluetooth Module Replacement: 10 단계, 이미지 3/3
    • Locate and remove the black screw in the center of the motherboard chip.
    • Remove motherboard and replace.
결론
William Tyler Wills
회원 가입일: 09/28/17
426 평판
안내서 4개 작성하였습니다
USF Tampa, Team S2-G1, Nance Fall 2017 USF Tampa, Team S2-G1, Nance Fall 2017 회원
USFT-NANCE-F17S2G1
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 20
전체 시간: 1,661
