주요 콘텐츠로 건너뛰기
Osmo Mobile Handle Disassembly
필요한 것
  1. Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: 1 단계, 이미지 1/2 Osmo Mobile Handle Disassembly, Osmo Mobile Handle Disassembly: 1 단계, 이미지 2/2
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Handle Disassembly: 2 단계, 이미지 1/2 Osmo Mobile Handle Disassembly: 2 단계, 이미지 2/2
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Handle Disassembly: 3 단계, 이미지 1/1
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Handle Disassembly: 4 단계, 이미지 1/2 Osmo Mobile Handle Disassembly: 4 단계, 이미지 2/2
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Handle Disassembly: 5 단계, 이미지 1/3 Osmo Mobile Handle Disassembly: 5 단계, 이미지 2/3 Osmo Mobile Handle Disassembly: 5 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Handle Disassembly: 6 단계, 이미지 1/3 Osmo Mobile Handle Disassembly: 6 단계, 이미지 2/3 Osmo Mobile Handle Disassembly: 6 단계, 이미지 3/3
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ustena Safa
회원 가입일: 09/28/17
345 평판
안내서 2개 작성하였습니다
USF Tampa, Team S2-G1, Nance Fall 2017 USF Tampa, Team S2-G1, Nance Fall 2017 회원
USFT-NANCE-F17S2G1
4 회원들
안내서 12개 작성하였습니다
댓글 10개
Bonjour,
La toute première étape est trop vague pouvez-vous donner plus de détails svp.
Je vous remercie d’avance
Guitt97ii - 답글
I would not call that a handle disassembly. This instruction takes you up to the things you need to do PRIOR to disassembly.
I can show you the rest in a video format if you’re interested
John M O'Donovan - 답글
Could you please show me how to fix the USB port that wenr inside the handle? on my Smove gimbal stabilizer
Juan Carlos Beltran -
My osmo has snapped off at the metal camera attachment. Can this be repaired ?
michelle Moore - 답글
Your help would be greatly appreciated
Emile Jansen -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 21
30일 전: 72
전체 시간: 8,168
